AT29C256 chips
Old May 16, 2001 | 09:34 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
AT29C256 chips
Just wanted to post a quick line that I finally got to use the AT29C256 chips (Thanks Dan!!). Very nice. I had a small problem with being able to program the chips but after shutting down ALL of my windows programs (including the control panel programs) they program easily and without problems (over and over and over again). I did not have to program the chips with FF's first and I did not have to restart the program. The key for me was to ensure that all windows programs were completely exited.
As a side note - I have my big cam / big head / big stall car running very well. So, don't fear the big cams with speed density. I have my 230/245 113LSA cam purring like a kitten on my stock bottom ended 350
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
[This message has been edited by TRAXION (edited May 16, 2001).]
Old May 16, 2001 | 10:11 PM
CanadianBeast's Avatar
Traxio, have you had a chance to run the car at the track? Do you think you'll get that 11? I hope so, thats a fast N/A car, especially on stock bottom end.
Good Luck
Old May 16, 2001 | 10:27 PM
leirch's Avatar
Tim,
Yep those At256's are awsome huh?
I saw forget the zif socket(didn't have one), and just soldered the flash prom in the carrier!
The SD beats the crap out of my MAF setup i had. I'm just having some problems getting the VE tables down.. I'm trying to make an evenly proportioned table with the process that you use(take some data, change some data and then alter the entire table with TC's graph function). But every time i do that i always throw everything off pretty good.
Brendan
P.S. yea the flash chips are sweet, definatly worth throwing the eproms away.
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 16, 2001 | 10:35 PM
TRAXION's Avatar
CanadianBeast - Nope, haven't been to the track yet. I am determined not to go until I have my driveshaft upgraded to a 3.5" heavy duty unit. I currently do not have a DSL installed (because none on the market will work with my current configuration) and I don't want to take the chance of twisting up this 1LE shaft and destroying either a part of my car or ... heh heh ... me - lol. I also have to admit that my current setup is not balanced. The 1-5/8" headers are surely choking my power. Fortunately, I have a set of Hooker Long Tubes sitting on the shelf. Unfortunately, I may be spending my money on a new tranny before I get them installed.
Leirch - Yeeeup, just soldering those puppies right into the carrier is a great way to do it. I am just happy to plug them into all of my HyperTech Adapters that I have laying around. Getting the VE tables down is pretty straight forward ... but, having some experience under your belt makes it a lot easier. Be patient - it will work out just fine Think small when you actually change the values by clicking on the graph. Little movements in the graph can make big changes in BLMs.
Tim
Old May 17, 2001 | 12:04 AM
james_fearn's Avatar
if you soldered the prom to the carrier then what device do you have to mate the carrier with the pocket programmer?
James
Old May 17, 2001 | 01:16 AM
93ND500's Avatar
I used a header off of an old 3 1/2" disc drive. Desoldered it, cut it to length, bent the pins to fit my programmer, and ran a bead of Probond polyurethane glue along the pins to help hold them it place. Click Here to see how it turned out.
Old May 17, 2001 | 09:28 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Hey, Tim, good stuff. One the Hex FF part, it may be due to my using FILEPROM instead of the Windows pgm with the Pocket Programmer. It appears those that do not have to use Hex FFs are using the Windows version.
Also, my Flash Prom would program, and read correctly as per the Pocket Programmer. But when I installed it in my car, my SES light came on and I couldn't even link to my ecm with Diacom. But I think it is a FILEPROM problem (and probably because I am using the previous version which may have an bug in it).
Old May 17, 2001 | 02:51 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
[B I am just happy to plug them into all of my HyperTech Adapters that I have laying around.[/B]</font>
You have a bunch of adapters laying around? Wanna part with one, i really don't feel like spending the money on a new memcal from GM. C'mon help an ICONer out.
And i'm already in line for your headers, what about the shaft? If it isn't spoken for, i guess i'll start that line too.
...ed
-=Traxion's Remnant Sale Racing=-
Old May 17, 2001 | 10:29 PM
TRAXION's Avatar
LOL @ Ed. I have 3 adapters. I could probably part with one of them. Contact me on ICON (or else I'll see ya in Ocean City this weekend if you are going).
Tim
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
