BIN for 327, start w/ 5.0 or 5.7 bin?
Old Jun 5, 2001 | 09:52 PM
Greenshamrock77's Avatar
I am going to make a custom BIN for my 327. This will be an 89 ecm/harness (no cold start inj.). I have to have a starting point, so which bin should I start with, 5.0L or 5.7L?
82' Z-28. 327" w/ flat tops. 216/228/112LS. Pocket ported 041 heads 1.94/1.50 SS valves. World Class T-5 from a 91'. Best run? Runs with 2001 vette to 150mph! Soon to be converted over to TPI w/ supercharger.
Old Jun 6, 2001 | 01:35 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Since you've got a 5-speed, I'd start with the 305 5-speed bin, and modify the cylinder constant.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 6, 2001 | 01:54 AM
JPrevost's Avatar
Car: 91 Red Sled
Just a thought but the 305 has a different stroke and bore than the 327. At least the 350 has the same bore. Wouldn't it probably be best to start with a 5.7 eprom? This is just a thought. About the 5 speed, I guess a 5.0L is the only way to do it.
, Jon (350 TBI!)
91 Red My website
Old Jun 6, 2001 | 05:40 PM
leirch's Avatar
I would probly get the APYP(89vette 6speed chip).
Then compare that to an 89 305 5speed chip.
From there you should be able to get a pretty decent chip to start out with.
Oh and the MAF does not have a Cylinder volume option(its not needed).
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 6, 2001 | 06:44 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Greenshamrock77:
</font>
I'd start with a 730.
The MAP system is not displacement sensitive. 327 has about nothing in common with either the 5 or 5.7L engines as far as design principals. 327 is kinda a high rpm engine and that's where MAFs run out of resolution, being a small displacement engine that would work for you with the MAF, but I don't see where going thru all the MAF scalers and stuff is going to be any fun.
Old Jun 7, 2001 | 01:05 AM
Kevin91Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by leirch:
Brendan
</font>
My mistake, I'm used to MAP stuff.
I'd still use the 305 5-speed chip then, or just use the 350 chip and modify the trans option for a 5-speed. Its your choice. Almost everyone uses the ARAP chip for MAF cars.
Old Jun 8, 2001 | 12:24 AM
JPrevost's Avatar
Car: 91 Red Sled
I just said that a 5.7 would make more sence because of the actual design. Same block as a 327 and uses the same heads (spark advance detonation etc.). What are the differences between the auto vs. standard eproms? Is there a difference in the ecm or just the eprom?
, Jon (350 TBI!)
91 Red My website
Old Jun 8, 2001 | 10:40 PM
leirch's Avatar
Their is no difference in the ECM, an ecm is an ecm, thats where GM saved their money.
The eprom is where the brains are stored in a sense...
Brendan
Old Jun 9, 2001 | 01:08 AM
Kevin91Z's Avatar
I've noticed quite a few differences between the 305 5-speed PROM and the 350 automatic PROM, at least in speed density cars. Usually its just minor fuel and spark changes. I dont know the reason, but I would imagine its because of the different heads, and engine size, they have different fuel/spark needs.
Rocket-Doc
Nov 14, 2015 02:08 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
