Lean pops on sudden TPS increase.
Old Aug 19, 2006 | 10:58 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Normally I'd fix this with a little AE, or ramp spark. I tried both. AE didn't make a difference. Spark made it worse. Any ideas?
even if I'm standing over the engine with the car in park, and I snap the throttle a little it will pop a nice fireball through the intake.
This car has a cc-306 cam and is 10.1:1 with a miniram, and 58mm tb, Super-8d version3 with VE mods to get BLM as close as possible, some inj constant changes, and I have the fans set so the coolant should never go over 200f or so. (185 thermostat).
It idles between like 75-79kpa, which seems a little bit much to me (would think it would be in the 60s). I adjusted valves like 5 times. They are not tight.
Anyway, heres a screen shot of an example. Pretty much, the second the TPS goes from 0 to something higher than say 10%, I get a POP, then the car pulls.
Any ideas?
-- Joe
Old Aug 19, 2006 | 11:28 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
That's definitely AE, in my book. But you probably have a super free flowing intake duct/filter, right? It's a very difficult problem to overcome. If I were you, I'd really fudge (increase dramatically) the VE in the lower RPM, high loads, to see if it gets better. And get as much dTPS AE in as quickly as possible without screwing it up too much elsewhere. Also decrease the AE decay, to make it last a little longer.
Old Aug 19, 2006 | 11:31 PM
You might also want to decrease the AE decay.
Old Aug 20, 2006 | 11:41 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
How far is your MAP from the plenum?
Is it a soft line or a hard material hose?
Could be some delay in there.
Old Aug 20, 2006 | 11:58 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hi,
Map is connected with like a 2" hard line to the center of the manifold. It shares a 3/8" vac port with the FPR, which is also connected with hard line.
-- Joe
Old Aug 20, 2006 | 12:10 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Which table would you recommend? I tried adding a ton to the "accel enrich delta pw factor vs coolant", with no change. Maybe i'm editing the wrong table?
See attached image, which tables would you try editing with?
On $58 (what i've been using for 5 years now) there is only 4 AE tables, and the one two that have the biggest impact were "accel enrich vs tps" and "accel enrich vs map".
-- Joe
Old Aug 20, 2006 | 12:11 PM
Z69's Avatar
Z69
From what I've read, a little more AE won't do it with a MR.
More like 150% to 200%
Old Aug 20, 2006 | 12:20 PM
JP86SS's Avatar
Hate to do this to you..
But in the sticky...
https://www.thirdgen.org/forums/diy-...e-thing-i.html
Might try the AE map multiplier tables. There are several ways to cover the transition in $8D.
Here is a nice post on the different ways to play with it. Specifically on TBI but the theories apply.
https://www.thirdgen.org/forums/diy-...=accell+enrich
Old Aug 20, 2006 | 12:39 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
A little more not enough? Okie. I'll double it. This is a brand new motor, so I dont have a baseline tune i'm starting fresh with super-aujp, which I picked since a lot of folks raved about it.
--Joe
Old Aug 20, 2006 | 12:45 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I was reading that. I'm not sure if the map table is going to help, because the map change isn't really that great. Maybe 10kpa swing either way, But I'll try it along with the delta tps table. What do you think? I guess if as Funstick says, the delta tps table makes the biggest "global change" i'll try that first.
The AE is a little less comprex on the $58 masks I'm used to. Oh well.
-- Joe
Old Aug 20, 2006 | 12:52 PM
JP86SS's Avatar
That's where I think the multipliers will help.
Can make a small change look bigger in the range you want it.
Old Aug 20, 2006 | 07:23 PM
Do you have a way to give the MAP signal its own port? Aftermarket regulators are usually not air tight at all and can mess with your tuning a lot. You could test it by disconnecting and plugging the regulator, and reducing the fuel pressure down to whatever runs smoothest, and see what your MAP reads.
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
