data logged now what?
Old Sep 15, 2006 | 07:52 AM
graphicideas1's Avatar
i data logged with tuner pro - now how do i view what i logged? I can watch it using the dash but is there any other way to see this?
Old Sep 15, 2006 | 11:33 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
ALDL Monitor chart tabs, dash display, and Flags list.
Press play and watch.
Old Sep 15, 2006 | 11:39 AM
i have done that - but how do i know when to add spark & fuel & at what point in the rpms?
Old Sep 15, 2006 | 12:00 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
This reminds me of a question I asked back in 2nd grade (or so): "Teacher, now that I can read words, how do I comprehend a book?"
Not that it helps answer your question, but it at least gives you some perspective on the magnitude of your question.
There is lots of information that guides you in "comprehending the book" in the stickies up top in this forum.
Old Sep 15, 2006 | 12:51 PM
Great reply / insult...Now who sounds like the 2nd grader?
Anyone else?
I have never seen the tables i need to modify, Maybe it will help to look at them, where are they?
Old Sep 15, 2006 | 12:58 PM
Mangus's Avatar
Transmission: T5WC
You mistakenly believe that I am calling you a second grader. I assure you I am not. What I was getting at is summed up nicely here:
Asking Smart Questions - Third Gen .org : F-Body : Chevrolet Camaro, IROC, Z28, Pontiac Firebird, Trans Am
Old Sep 15, 2006 | 01:15 PM
Ok fair, my 1st problem is that i can not read my bin. Is this done with a chip reader or using the obdI port?
Old Sep 15, 2006 | 01:18 PM
Mangus's Avatar
Transmission: T5WC
You can actually do it either way if you have a P4 ECM (1227165, 1227730, etc). Chip reader is probably more common and easier at this point, and it is compatible with all ECMs. To do it with a reader, it is recommended that you get a burner (BURN1 from <u>DIY Fuel-Injection Tools:</u><br>Created by an EFI enthusiast for EFI enthusiasts like you! : Moates.Net is highly recommended at $85), and a memcal adapter that allows you to simply pull the memcal and plug it into the burner/read (moates has that as well). If your ECM does not have a memcal (i.e. a C3 ECM), then you simply need to pull the chip from the ECM and plug it into the reader.
To read via the ALDL line (for P4 ECMs), download ECM852 from moates (same link as above). It requires that you run it in DOS mode (boot to dos) if running on Windows XP. Once running and connected to your car, it has an option to dump the image over the ALDL line. If you can't get that working, let me know and I can write a utility that allows you to do this.
We could get more specific if we knew what ECM (or at least year, model, and engine) you are referring to.
Old Sep 15, 2006 | 01:32 PM
Thanks, it is a 88 gta 350. I think when i am see this it will make things more clear.
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
