Forbidden
Old Apr 28, 2001 | 12:44 PM
transfixleo's Avatar
Forbidden
Hi Gang,
I am new to this section and needless to say I am fascinated with this. I tried to read some of the files asscociated with the Prom Burning Introduction and when I clicked on them, this is what I got:
Forbidden
You don't have permission to access /VOL4/96398/162145/1138118.jpg on this server.
Am I doing something wrong or are they down for some reason?
Also, I read in one of the posts that for @$250 you can build up a laptop to act as a scanner. I pay more than that for updates on my Snap-On Scanner. What happens with different model years, or is this for reading the BIN file?
Old Apr 28, 2001 | 10:18 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Go here...
www.picturetrail.com/traxion
Click on EPROM Programming. Dirk is in the process of moving those pics to thirdgen.org's server so this problem will be resolved shortly.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Apr 29, 2001 | 06:52 AM
Thanks, I didn't want to miss this stuff!
Old Apr 29, 2001 | 01:25 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Leo,
That Laptop/scanner you are refering to is Diacom, and its just software and a cable that allows you to view operating parameters like a scantool. The updates you purchase from Snap-On include things like Troubleshooter updates, new DTCs as they come out, and other things. I make sure I keep my Snap-on Vantage updated, its to valuble of a tool.
Oh yeah, and your Snap-On scantool also has things like bi-directional controls, something Diacom can't offer. You have an MT-2500 right?
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited April 29, 2001).]
Old Apr 29, 2001 | 01:50 PM
CanadianBeast's Avatar
If you have a maf system, 165 ecm you can use Craig Moates free software that does everything that diacom does. I'm not sure but I think that it'll work for a 730 ECM but it might ake some meesing around. All you need is a cable that you can build or buy from AKM as mentioned in Traxions article and a laptop. It's such a simple program that any laptop with dos will do. I'm using a 386.
Old Apr 29, 2001 | 07:40 PM
Yes, I have had it since 1990. I have to be selective about the updates that I get because of the price. I have the Vantage and was able to pick up an update from the internet to bring it up from a V1 to V3 for about half Snappy's price.
[This message has been edited by transfixleo (edited April 29, 2001).]
Old Apr 29, 2001 | 08:10 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Diacom is great for PROM burning becuase its an easy to use system to watch data. But if you are in the auto repair field, the MT-2500 is the way to go, so I would just stick w/ that. I bought my Vantage w/ Version 3.0 already, so I have yet to buy an update for it. The Scantool I use is the Tech2, and updates are free via the GM Access Server.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old May 2, 2001 | 09:58 PM
FastBroker's Avatar
GMTech/anyone:
Can you download lots of data from the MT2500 snap-on scan tool somehow??? I have one, too, and it doesn't look promising from the manual. Jut looks like you can make a remote terminal out of a laptop, or something. The MT2500 does take short "movies" which are not big enough for me and are not downloadable (word?). Would like to have lots of data to download and analyze with Excel...
HELP
Old May 2, 2001 | 10:31 PM
I'm telling you if you want lots of data available to excel, (in fact it saves directly in excel format) you should get craig moates program, it's really good, and if your burning a prom, by your presence on this board I assume you are, it's does everything you need and more. Plus it's free.
http://members.tripod.com/moatesenheimer/gmecm/
Old Aug 8, 2001 | 09:07 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Could someone PLEASE transfer those graphics over to the thirdgen.org server??
I just ordered my '89 harness and want to begin the repinning process for my #730 ecm. I wish to begin bench testing my miniram project this winter.
I've got a FLASH EEPROM to add to my socket, and should start ordering the prom burning stuff in September. Hopefully I'll have my shortblock done by Labor day and I can start saving up for the last pieces of the shortblock puzzle: Worked cylinder heads (I wanna be like Tim Siford ) and a hairy SD program to make it purr at idle and roar at WOT.
(Hi Trax! Congrats on the low 12's, btw.)
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Aug 8, 2001 | 09:54 PM
TRAXION's Avatar
<font face="Verdana, Arial" size="2">(Hi Trax! Congrats on the low 12's, btw.) </font>
I guess old news is still good news. Heh heh ... wait till I hit 11's. Now if I could just get the money for the Denny's Driveshaft, the PBM coating for my LTs, and the Mufflex Y-pipe I could actually give it a go!
Tim
Old Aug 9, 2001 | 07:30 AM
TRAXION's Avatar
Oh yea ... I talked with Dirk awhile ago about moving the pics. I also just sent him a new e-mail about the same thing. I may update the PROM article to include the FLASH stuff as well as a pointer to the newest $6E stuff. We'll see.
Tim
Old Aug 9, 2001 | 09:49 PM
Ragin'87's Avatar
i've asked before.. and didn't have a laptop, or any time, but now that I have a laptop, and some(very little.) time, I'll ask again. Is there any software, like Craigs for the TBI computers? I have plans for a pretty wild setup a few years down the road, but I want to use the TBI, kind of a simple but fast EFI car GM should have built in the first place as my senior design project. From what I can tell, it will require extensive PROM work, so I figure I should start now, but I can't seem to find any info on burning PROMS for the stock TBI computer.
I have a 92 RS if that makes a diff in computers. Thanks.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
Old Aug 9, 2001 | 11:35 PM
Brent's Avatar
<font face="Verdana, Arial" size="2">I can't seem to find any info on burning PROMS for the stock TBI computer.</font>
Search for 747 and 8746. Lockers (a high end DIY scantool) is another to search for if you have some electronics knowledge.
Also read Programming 101 at www.diy-efi.org
Old Aug 10, 2001 | 02:05 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I have the snap-on MT-2500 scanner.
Snap-on has additional software called Scan-Grafix that lets you see and graf live data and record it on your laptop direct from the scanner.
Louis
Convertable
92 Z28 305tpi Auto
1/4 at 13.23 @ 106.1mph w/Paxton 10psi, Ram air mod,Water methanol inj.,52mm T/B,ASM Large tube runners, ported upper & lower intakes,AFPR,23# injectors,1.6 roller rockers,slp tri-y headers,3in. cat,3in. gale banks cat back system,3.42 gears,17x9 camaro SS wheels, 285x40x17 tires,and much more.
http://www.lbsz28blown.cz28.com
Old Aug 10, 2001 | 08:13 PM
Ragin'87's Avatar
Thanks guys.. the Snap On scanner is out of the question. I'm an entering freshman in college, which as is well known means I have NO money. I'm guessing my ECM is a 746 then? I'll search for it.. thanks.
Anthony
MFarmer
Carburetors
Jun 20, 2013 11:01 PM
Cogburn
Sep 26, 2011 10:28 PM
jeff_blake
Sep 24, 2010 06:51 PM
mw66nova
South East Region
Apr 21, 2008 07:45 PM
ninety1TAgta
Aug 29, 2002 04:57 PM
