more eraser problems....
Old Aug 24, 2001 | 06:26 PM
jmon92conv's Avatar
This is in regards to the earlier post by me. Thanks for everyones help so far. I bought a new GM memcal to erase, science mine would not. Now the new one won't either. I am not looking for some one to burn a chip for me, but if someone is within a hour of Louisville, KY, and willing to help, I would very much like to talk to you in real time.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old Aug 24, 2001 | 07:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by jmon92conv:
[B]This is in regards to the earlier post by me. Thanks for everyones help so far. I bought a new GM memcal to erase, science mine would not. Now the new one won't either. I am not looking for some one to burn a chip for me, but if someone is within a hour of Louisville, KY, and willing to help, I would very much like to talk to you in real time.
[B]</font>
have you gotten any to erase read write?.
Do you have any loose eproms?.
If you haven't gotten anything to work and want to just try a couple epeoms to see if you got things down right email off list, and I'll send you a couple (need to know what size your working on)
Old Aug 24, 2001 | 07:41 PM
jmon92conv's Avatar
All i have is 2 stock eproms on memcals. I can read them fine, I just can't get them to erase to fix the VATS. I have a stock 92 TPI car.
Jeremy
Old Aug 24, 2001 | 08:37 PM
leirch's Avatar
Just a question, but are you sure they are reading ok? I mean, if you have a pin off from the memcal to pocket programmer(ie, the adapter that Tim came up with), then it would read what it could from the pins that are touching... if one pin is off it won't read that its erased.
Have you tried viewing the bin that you downloaded? If it works fine then I'd definatly try some other eproms to see if you can erase some of them, if you cannot then I would look towards your eraser as being the problem.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Aug 24, 2001 | 08:48 PM
jmon92conv's Avatar
I have viewed the file from the prom, so it is reading. I have tried to erase both proms with no luck. The eraser might be messed up, but it lights up, and I have no other way to check it. This is getting frustrating, my car has been down for 3 weeks.
Jeremy
Old Aug 25, 2001 | 01:49 PM
jmon92conv's Avatar
Grumpy, if you have time can you help me out? Send me an e-mail and I will try to tell you whats up.
Jeremy
Old Aug 25, 2001 | 02:47 PM
jmon92conv's Avatar
OK, with the addition of a new GM key it will start. But the problem is, it is in limp home mode. Any ideas?
Jeremy
Old Aug 25, 2001 | 07:20 PM
leirch's Avatar
If its starting in limp home mode, more than likely the chip did get erased. Have you tried programming the chip with different voltages?
Brendan
mike89z
Sep 5, 2002 10:53 AM
lars92RS
May 22, 2001 05:35 PM
leirch
Mar 2, 2001 09:06 PM
doc
Feb 13, 2001 01:58 PM
David 91RS/Z28
Oct 6, 2000 08:41 PM
