$32B in 165 ECM how to disable checksum?
Old Aug 26, 2001 | 07:47 PM
jcygan's Avatar
What do I edit in the pocket programmer editor to dissable the checksum check on this particular EPROM?
Old Aug 26, 2001 | 10:02 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I read somewhere recently that if you change the prom ID to 0xAA that it disables the checksum routine. You planning on running an emulator?
Old Aug 26, 2001 | 10:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by afgun:
I read somewhere recently that if you change the prom ID to 0xAA that it disables the checksum routine. </font>
That is it.
Old Aug 27, 2001 | 09:43 AM
jcygan's Avatar
Would I do this in Pocket Programmer's editor? If so, at what location is the PROMID?
Or, can I just put this in the PROMID section of TunerCat? (Wouldn't that work out to entering 170 in the id field of tuner cat?)
Old Feb 20, 2003 | 06:20 AM
JPrevost's Avatar
Car: 91 Red Sled
It isn't the prom id that needs to be changed, it's the mask id! The mask id is also the check byte. Editing the prom id does nothing except change what is output through the aldl stream, nothing more. I know this is an old topic but I was just doing a search and noticed the typo. Besides....the prom id is 16bit, "AA" is only 8bit so what part of the prom id would you edit, common sence says that doesn't make sence.
The location of the prom id and mask id are usually next to each other. In the 8746 and 7747 (TBI ecms) location D002 and D003 are the prom id and the mask id is at D004. If you've got Craig Moates multiprogram it's best to set the mask id to AA, prom id can be anything you want. Locations D000 and D001 are the checksum which matters if mask id is anything other than AA.
Old Feb 20, 2003 | 10:55 AM
TORC's Avatar
Newbie type question
Does disabling the checksum routine serve any other purpose besides allow the use of an emulator?
Old Feb 20, 2003 | 11:12 PM
JPrevost's Avatar
Car: 91 Red Sled
Not really, none that I can think of. Except maybe you're using an editing program that isn't recalculating the checksum.
Old Feb 20, 2003 | 11:20 PM
funstick's Avatar
hmm unless tc released there live emulator support or a few folk are editing in hex i doubt the average guy need to disable checksum.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
tmellott89
Oct 14, 2015 02:06 PM
Jlanz55
Sep 29, 2015 08:55 AM
