pocket programmer problem....
Old Oct 17, 2001 | 04:14 PM
jmon92conv's Avatar
Well, I haven't given up yet. The programmer will read the chip, winbin will edit it, and the eraser erases it, then the PP will not recognize that the chip is erased. any ideas?
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old Oct 17, 2001 | 05:20 PM
davidjon_99's Avatar
<font face="Verdana, Arial" size="2">Originally posted by jmon92conv:
Jeremy
</font>
Is the chip a 27Cxxx? If so, make sure you are exposing it to the UV eraser for a long enough time. I erase mine for a minimum of 10 minutes.
Does it happen with just this one chip? If so, the chip is probably bad.
Have you ever been able to program a chip with this PP? If not, then you might need to get the PP serviced.
Just my $0.02 worth.
1991 Chevy C2500HD 5.7L HD. 16147060 ECM
Mods: Crane PowerMax 2030 cam 204I 214E @ .050 and 423I 446E lift, Jacobs Pro Street Ignition System. Using DataMaster and TunerCat with $85 ECM files.
Old Oct 17, 2001 | 09:03 PM
jmon92conv's Avatar
I am using a 27c256. I sent the 2 memcals I have to a guy who checked them and they were erased. The PP is new, which leds me to think I am doing something wrong, but I can't figure it out.
Jeremy
Old Oct 18, 2001 | 07:32 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Do you have the PROM in the PP socket correctly? This also happened to me until I realized that I had the PROM in the 32 pin position instead oh the 28 pin position.
Old Oct 18, 2001 | 01:52 PM
jmon92conv's Avatar
Ok, I think I made a stupid mistake. I think it was in the wrong slot. Let me try it tonight and I will get back and let you know. Man I feel really stupid
Jeremy
Old Oct 21, 2001 | 12:03 PM
jmon92conv's Avatar
OK, I inserted the adapter exactly like the little diagram has it and it still says it is not erased. Any other ideas.
Jeremy
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
randy210
Oct 15, 2015 03:43 PM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Sep 21, 2015 10:24 AM
