engine bogs when quick throttle
Old Oct 23, 2001 | 12:33 AM
v8power's Avatar
when I hit my trottle really quick at idle then let off the engine bogs for a sec.
when at part throttle driving when i punch it the same things happens other that that it seems to run alright
any ideas what to look at to find out why it doing this?
1986 IROC 350 5spd
just installed a TPI from a 1988 IROC, 24# lt1 injectors,165 ECM MAF, custom sub frame
GOT TOURQUE ?
Old Oct 23, 2001 | 11:18 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by v8power:
</font>
Did you change the injector constant?.
Old Oct 23, 2001 | 11:59 AM
v8power's Avatar
YES I am running 24# LT1 injectors and the constant is set to 26# my BLM's are almost all at 128 Glenn help me get that set up when I was there
I am running the 89 1LE code with some slight mods
1986 IROC 350 5spd
GOT TOURQUE ?
Old Oct 23, 2001 | 02:13 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Darryl, you should also mention to Bruce your heads and cam, as it isn't a stock TPI and though it isn't "radical" it is definitely not a stock setup.
My immediate reaction is something in your Accelerator Enrichment, which is done completely different on the 165 than it is on a 7730. On the version of the 6E that I have, Accelerator Enrichment is not even defined and I do not know if TunerCat has defined it on their latest version of the 6E.TDF.
You might consider playing with the %TPS to Enable PE at the 400 rpm level. It appears that combination of fuel and spark need to be played with. Maybe you need more, maybe you need less. But it sounds like you need to play with it.
Old Oct 23, 2001 | 03:38 PM
89vette's Avatar
Tunercat's TDF for the 165 is very limited. Terry Kelley's GMEPro is very through and is my preferred program for the 165. I'll be happy to forward Terry's email if you like.
Glenn, that's and interesting suggestion on the PE mode enable at 400 RPM. However, if its anything like my car when I had the miniram on, I had the stumble at RPMS higher than that. Worth a try though. MAF cars by nature are not the quickest on throttle response from my experiance. Now that I have SD, my throttle response is very quick. Of course the Superram intake was the most dramatic change to throttle response. Getting back to the 165 though, in GMEPro, there are 4 tables that affect AE or pump shot.
Jason
Old Oct 23, 2001 | 04:17 PM
v8power's Avatar
So what table is that in (TPS vs PE)
I only see stuff referring to WOT vs A/F
in the $6E
1986 IROC 350 5spd
GOT TOURQUE ?
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
