Pulling from an unmodified Memcal...
How can I use my pocket programmer to pull the info off of my stock prom still in the memcal. I am under the impression I can do this, and then simply use one of several piggybacks (like a hypertech) I have to just bypass the stock chip. I need the info for tunercat first though. Any help?
Paul
90 Red Convertible
100k running great
ZAINO!!!
383 Stroked.... LT4 Hot Cam... Forged Elgen Pistons Scat 9000 Crank Elgen 5.7" rods New Lifters w/ 1.6 Rockers and hardened Pushrods Super Ram Intake Hooker Headers and Y pipe into Gutted Cat with Monza Mufflers (WAY TO LOUD!!) Adj Regulator K&N Shift Kit High stall converter 160 termo, ZR1 Rims.... Red Calipers....Alpine head unit, Kenwood 6x9 4 ways, Polk DX 6 1/2 compnents, MTX 240 amp, Viper 550 alarm,
www.corvetteforum.net/c4/nomar116/
Paul
90 Red Convertible
100k running great
ZAINO!!!
there is a few pictures in the "Prom Burning Introduction"
https://www.thirdgen.org/newdesign/t...om/1138122.jpg
https://www.thirdgen.org/newdesign/t...om/1138134.jpg
take a look at these
1986 IROC 350 5spd
just installed a TPI from a 1988 IROC, 24# lt1 injectors,165 ECM MAF, custom sub frame
www.members.home.com/v8power/
GOT TOURQUE ?
1986 IROC 350 5spd
GOT TOURQUE ?
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Read through Traxion's Prom Burning Intro. He gives you all Digikey's part#'s to order the pieces you need. Then modify them as he did by reading what he wrote and looking at the pictures.
I recently did that and it was extremely easy to do and works great. I just cut and pasted the part#'s listed into Digikey's website order form. You don't even need a cutoff wheel to modify that blue piece with the pins. You can pull out the pins you don't need with a pair of needle nose pliers. I then cut the blue plastic down with a small coping saw. Easy as 1,2,3.
This may not be the best advice for the uncautious, but it will get you out of a jam.
I had the same problem. I have a piggy-back for the new chips but like you needed the info from the stock memcal. I drove around for a day and could not find a header so I improvised.
I used "T" pins. I just cut the tops off and put a slight bend in them to fit. BE VERY CAREFUL not to let the pins touch. I used this for two different memcals while waiting for the header I ordered to show up, and it worked great.
'92 RS 350 Big Mouth TPI 5spd 2.73 lmtd slp Daily Driver with "ISSUES"
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Have you tried an ECM dump in-situ with my program? Might work for you, might not with the SLP/TPIS type stuff, don't know. Could be worth a try if you're set up for it.
Craig,
I havnt, mainly cuz I have no idea what your talking about
Still cant get your software working and still trying frustratedly...
Paul
90 Red Convertible
100k running great
ZAINO!!!
Still cant get your software working and still trying frustratedly...Paul
90 Red Convertible
100k running great
ZAINO!!!
wigmobile
Feb 26, 2025 02:56 PM
