8746 - Confirm A/C input signal is 12v?
Old Oct 29, 2006 | 12:13 AM
ericruhl's Avatar
Car: 77 CJ7
Engine: AMC 401 w/ 454 TBI & 8746 ECU (61)
I don't have A/C, but I'd like to use this input to trigger a higher idle rpm. I just wanted to confirm it's a 12v input? The A/C input is on pin B8. Better to be safe and ask first
Old Oct 29, 2006 | 03:39 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Just curious as to why you want a higher idle RPM with no AC.
Should be a system voltage level input, though.
Might want to put a high impedance resistor in line with the signal, and possibly a high impedance resistor to ground on the same line. But, I'm not really sure if it's necessary. I'm not sure what's built into the AC input on the ECU. On some types of cars, where the AC is not controlled by the ECU, but the ECU still gets a signal to see when the compressor is on/off, there's a diode and resistor (or something like that) built into the wire harness, close to the clutch, to give a safe, consistant signal.
Old Oct 29, 2006 | 07:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the A/C in is +12 volts, open for no signal.
RBob.
Old Oct 29, 2006 | 10:03 AM
ericruhl's Avatar
Car: 77 CJ7
Onboard air compressor
Thanks for the speedy replies!!
KCG
Jun 24, 2020 04:33 AM
Elephantismo
Feb 13, 2019 12:51 AM
Veaceonee
Sep 29, 2016 08:15 PM
buckeyecelt
Sep 24, 2015 05:50 AM
89 formula TPI
Sep 7, 2015 11:06 AM
