blm doesnt seem right
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
I was doing some logging via winaldl and it just doesn't seem right. I'm getting a 128 blm reading but am throwing a 02 sensor code and a rich code every so often? any explination for that
Car: Death Mobile
Engine: 666 c.i.
Bad/flakey O2 is a good possibility. Definitely best to change it to see if that cures the problem...especially if he O2 sensor has a few years/miles on it.
If it still happens after changing the O2 sensor, try to determine if this happens under some specific operating condition (going up/down a hill for example). Some times you may hit P/E (due to the TPS settings) but not really have the "pedal to the metal". But because you are in P/E, the BLM goes to 128.
But I agree with AtomicTruck and would start with a good O2 sensor.
Car: 92 camaro rs
yeah it doesn't matter what rpm im at its always 128 ill go get a new o2 and see if that helps
thanxatomic/grim
thanxatomic/grim
Car: Death Mobile
Engine: 666 c.i.
Two other things: 1) Is it always stuck in the same cell? 2) Are you using an actual eprom or Flash Memory with an adapter? If you are using an actual eprom, how many times has it been used and are you constantly increasing the erase time?
I found that eproms need to have the erase time increased after every few burns or the eprom MAY appear to re-program correctly but in fact give "weird errors".
Hopefully, you "saved" the original eprom and can try using that to see if the problem persists or if it goes away.
(Debugging requires a bit of creativity to isolate problems sometimes...you need to look at ALL the differences you have from stock and go backwards, trying to eliminate each difference until you find the source. If you have already tried all this, then go back to the O2 sensor...I'm just tossing out ideas that you may not have tried or thought of).
Car: 92 camaro rs
no it's not stuck in the same cell but it is a 27a32 eprom i think and Ive only prommed it once with justa few things like fan cut on and off for my 160 therm. and i turned off the shift light cause i have an auto and for some reason it was coming on but that is it
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
For starters, a TBI ECM does not control the fan On/Off points. And if you have an auto, have you rewired your engine harness for the TCC?
Car: 92 camaro rs
it came with an auto shift lift never came on before then a cpl months ago it started. Only modifications are a 3 in exhaust straight from the y pipe no cat magnaflow 1in 2 out muffler and an open element
Car: Death Mobile
Engine: 666 c.i.
Remember to increase the erase time by a minute after every so many burns ... but eventually, the eprom will no longer erase properly, no matter how long you erase it. Give that a try first.
If the same thing happens try changing the O2 sensor and another increase in the erase time.
