New fuel injectors and programming
Old Apr 25, 2007 | 06:54 PM
vetteboy86's Avatar
I installed a set of 30's in my car up from the 24's that were in there. I have changed the injector constant and was wondering if that was all that required changing at this point?
Old Apr 25, 2007 | 07:30 PM
ULTM8Z's Avatar
Re: New fuel injectors and programming
I asked that question a little while ago. The advice I received was to scan the car during operation and check your readouts to see if you're running rich or lean. Then adjust accordingly.
Old Apr 25, 2007 | 09:09 PM
vetteboy86's Avatar
For sure I will do that. I am however more worried about right now. I just put the new injectors in and what to drive the car. I was wondering if it would be okay to just change the injector constant to get the car running. I have also heard that I can turn the fuel pressure down and use the same tune??
Old Apr 25, 2007 | 09:37 PM
ULTM8Z's Avatar
I think you can drive the car ok. The computer has some ability to trim fuel on its own in closed loop. IIRC, its in open loop where you'd be rich if the tables are not adjusted for the bigger injectors. Though, someone here with more expertise should correct me if I'm wrong about that.
I wouldn't turn down your fuel pressure.
Old Apr 26, 2007 | 02:25 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Change the constant and scan the car, should be fine
You may have to change the AE some.
/N.
Old Apr 27, 2007 | 06:20 AM
vetteboy86's Avatar
Well I changed the fuel injector constant on the chip and installed. Something is wrong because as soon as I key up the ignition the cooling fan comes on full. Any ideas?? I am going to revisit the bin, and make sure i programmed into the right location.
Craig
Old Apr 27, 2007 | 08:40 AM
ULTM8Z's Avatar
The chip didn't get programmed properly. Make sure you're putting it in backwards in either the PROM burner or the memcal.
Old Apr 27, 2007 | 09:24 AM
Z69's Avatar
Z69
You may want to multiply your start up pw table by 24/30 or 22/30 if it's a stock table.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
