Why in the world...
Old Aug 14, 2007 | 07:40 AM
jonarotz's Avatar
Car: 91 Z28
Why in the world...
does my tps % show around 25% when I am actually at 90-100%? Has anybody ever had this problem?
Old Aug 14, 2007 | 02:39 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
Re: Why in the world...
hi
a friend of mine had a similar problem on his 1989 corvette...
TPS stuck at 1,2xx volt, regardless of TPS position..turned out to be the ECM...
otherwise..check the TPS if resistance(disconnected) or Voltage(connected) goes smooth with opening
Old Aug 14, 2007 | 04:41 PM
jonarotz's Avatar
Car: 91 Z28
With a voltmeter hooked up I get 4.06V @ WOT and at the same time the scantool/laptop show 1.35V and 13% throttle position. closed throttle shows .62 volts...ECM???
Old Aug 14, 2007 | 04:57 PM
titchener's Avatar
Are you measuring that voltage at the sensor output or ECM input? If your measuring the sensor output measure it also at the ECM input, if the voltages look good there try cycling the connector (unplug and plug back in) if the reported voltage is still low it probably is a bad ECM.
Good luck-
Paul T.
Old Aug 14, 2007 | 09:05 PM
jonarotz's Avatar
Car: 91 Z28
Thats what I did...just narrowed it down to the ecm. Borrowed one from my little bro and it solved it. The car is a whole new animal now!
Thanks guys!
Old Aug 15, 2007 | 05:59 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
hi!!
glad you found it...just want to add another note....
i looked at my recorded datamaster files, and fount the TPS volts stucked at 1.37Volts..pretty the same, you observed..htis was the ´165 ECM on the 1989 Vette..
interesting, isn´t it?
Old Aug 15, 2007 | 07:41 AM
jonarotz's Avatar
Car: 91 Z28
Wow! that is a little strange. They must share some common citrcuitry. I did notice if I smacked the ecm it would read what it was supposed to. I am suspecting a bad solder joint, but since these circuit boards are epoxied there really isn't much I can do to fix it.
Old Aug 15, 2007 | 08:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If th ECM is the '730 as for your '91, it is a conformal coating. Easy to remove with some thing such as BrakeKleen (acetone, toluene, goof-off, etc).. Can even solder through it if needed.
RBob.
Old Aug 15, 2007 | 09:59 PM
jonarotz's Avatar
Car: 91 Z28
Good to know. Yeah it is the 730 from my 91. I will look into it...now if I can only find the culprit.
Old Aug 15, 2007 | 10:41 PM
11sORbust's Avatar
not an expert but I would trace the ciruicts for all the tps pins....
Old Aug 16, 2007 | 01:10 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
that is what i will do tomorrow...i will let you know what came out
88fastgta
May 27, 2017 04:29 PM
Grifstoy
South East Region
Jan 17, 2015 09:06 AM
MOTO RR
Wheels and Tires
Jun 4, 2014 11:00 PM
ThePain
May 2, 2010 07:48 AM
