O-Meter with LC-1 reviews?
Old Oct 21, 2007 | 04:07 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
I've done a search and can't seem to come up with anything...
does anyone own this combo? opinions?
I've been reading about it on moates.net, seems pretty cool. One thing that I found weird was you cannot upload the datalogs to your PC, but I'm not quite sure yet if thats super important.
I'm looking into purchasing a wideband to eliminate some guesswork, so I figured I would ask.
Old Oct 21, 2007 | 04:17 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Re: O-Meter with LC-1 reviews?
I like mine, works great so far.
Old Oct 22, 2007 | 09:00 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Mine too!
Old Oct 22, 2007 | 09:04 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
thanks for being so vivid with your experience guys!
haha.
Old Oct 22, 2007 | 09:59 PM
vernw's Avatar
Sorry. I use my O-meter strictly as a visual dsplay. My WB's are tapped into my data stream for data logging.
Old Oct 22, 2007 | 10:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i was wondering about this myself. I just wanted the cheapest way to get wideband o2 on my car wiht a read out so i know what the air fuel ratio is and tune from there
this seems like the thing to go with
Old Oct 24, 2007 | 09:45 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I love mine -- leave it hooked up all the time to help tune my carb.
Very Very Usefull and so cheap everyone should really have one that is serious about tuning.
Old Oct 24, 2007 | 10:27 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
You can datalog with the software and a laptop that comes with the LC-1.
Old Oct 24, 2007 | 11:42 AM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
I love my O-meter.... but I use it for a completely different purpose. In Code59 we have it outputting the Knock Retard that is in the ALDL stream out one of the ECM outputs and have it displaying that number to the O-meter. So it will show you exactly how many degrees of KR you are getting. I use the HI feature in the O-Meter to have it flash HI if it is above 6 Degrees of KR. (on a turbo vehicle any more and damage can occur)
To do this we had to make a simple Cap/Resistor Circuit and have it feed into the o-meter. We then added a table to Code59 and test constant that would let us fine tune the output to match the Cap/Resistor circuit so if you went with ai different gauge or circuit, you could fine tune it to match your setup. - I didn't come up with this, Turbodig is the one that figured out the ASM and the circuit, I just did all the testing. It works awesome.
This version of code59 with the knock output hasn't been released yet but should be coming down the pipe in the next release.
Here is the circuit and table. The ECM in use is the 749.
Old Oct 24, 2007 | 05:59 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
i thought that was the LM-1
Old Oct 24, 2007 | 10:55 PM
vernw's Avatar
LC-1 too.....
Old Oct 24, 2007 | 11:04 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
JAW is another cheap option (Just Another Wideband controller)
Old Mar 13, 2008 | 03:30 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
looking to bring this thread alive since i'm looking to start datalogging wideband as well as narrowband readouts..... from what i understand, all i need is the following:
o-meter with sensor and wire - 243
bung and plug - 8
$251
is there any way to get a readout anywhere else other than cutting a hole in the exhaust????
also, about the datalogging, i'm gonna be using the LC-1, but is there a USB connection on the o-meter so i can datalog on my laptop? or how does it work?
F-body-fan
Jan 12, 2023 01:49 PM
PurelyPMD
May 5, 2016 04:57 PM
3rdgenkindagal
Sep 29, 2015 01:41 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
