low map surging
Old Nov 22, 2007 | 05:48 PM
getsideways's Avatar
low map surging
this surging is driving me crazy. i cant seem to get rid of it. when im cruising its fine, my afr,s are swinging from 1.01-.98 lamda. if i let of the throttle slightly the afr,s swing from 16.1 to 12.0 every second and a half or soo. this is generally around 1600-2400 rpm at the 20kpa range. i keep messing with these 2 tables. is this right? and what direction do i go with these tables? ive been lowering them. thanks
Old Nov 22, 2007 | 09:15 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: low map surging
Might want to slow down the integrator (should mean increase the integrator delay vs airflow). Just a guess though...
==>> Have you tried Open loop yet?? If no surge in open loop, keep trying the closed loop stuff, otherwise.............
Old Nov 23, 2007 | 01:50 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Re: low map surging
Drop the Prop Gain in that part of the table by 5% and then repeat. You need very little prop gain at low MAP and low rpm
Old Nov 24, 2007 | 05:30 AM
devilfish's Avatar
Re: low map surging
On my 730 SD vette. I hade to lower Prop gain 30% to minimise low rpm surge/jerking. Its so sensitive with a manual car
Its not 100% perfekt, but good enough.
To get it 100% for me is to use open loop only. But I dont whant that.
Bye.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
customblackbird
Oct 1, 2015 04:30 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
adelane
Sep 9, 2015 08:51 PM
