$58 in NVSRAM module?
Old Mar 31, 2008 | 11:17 PM
Blown87IROC's Avatar
What would it take to run $58 in MonteCarSlow's NVSRAM module?
Old Apr 1, 2008 | 07:54 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Re: $58 in NVSRAM module?
A lot of work...
You might try checking out this website: http://www.code59.org/
Old Apr 1, 2008 | 06:25 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
I know TurboDig worked on it some but not sure where he is at with it. I think he put that on hold, unless we need more RAM, while he works on some other features that he wants to get done.
Old Apr 1, 2008 | 09:49 PM
It looks like the problem is in $58's ALDL code. I’m not sure if it’s mode 2 or mode 4, or both that are screwed up. Which are you using Monte? I found I’d downloaded RTP4.zip at some point from somewhere but don’t remember where. Isn’t that yours, Monte? Other than how to fix the $58 ALDL problem, it seems to have all the rest of info needed.
Does anyone have a map of $58's RAM they're willing to share? That would sure help me try to sort out the ALDL differences between $58 and $8D (as well as document my $58/$59 source code).
I ordered an NVSRAM module from Moates yesterday and would like to have this fixed by the time it arrives.
Old Apr 2, 2008 | 12:31 PM
Engine: 5.7L TPI
My little hack to the $8D code relies on the existing ALDL mode 2 and 3 commands working, in addition to a restructured mode 4 so that memory can be written to via ALDL. And then what makes it all work as an "emulator" is rewriting the $8D code so that it looks into the nvram address space for all calibration data instead of eprom...
Old Apr 4, 2008 | 12:14 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Is there a thread on this? I must have missed it.
-- Joe
Old Apr 4, 2008 | 12:33 PM
Engine: 5.7L TPI
-- Joe
Dare I be funny for a moment... ?
It isn't spelled out in one single thread, but all the details of how to do it are posted for all to freely find. The hardware can be done for under $20 if you are skilled with a soldering iron, but failing that a through-hole version of the hardware is available from Moates as a bag-of-parts sold at near cost.
The whole thing works like a charm, and even real time 'emulation' is possible (but that feature is nonexistent due to lack of s/w for PC).
Old Apr 4, 2008 | 12:39 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
So you'll have that done soon, yes?
Old Apr 7, 2008 | 06:34 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I just checked it out. Kinda neat. I like the future idea of doing everything through the aldl port with a GUI, would keep me from having my ostrich stuffed up the dash.
-- Joe
Old Apr 7, 2008 | 08:08 AM
Engine: 5.7L TPI
-- Joe
Yeah, that is my favourite part of it. No mess of ECM guts sitting on the passenger side floor! My wife's 83 T/A has the ECM (a 727) mounted in the engine bay and having the nvram module works really well in that situation!
Old Apr 7, 2008 | 08:12 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have to read a bit more, but to make it works requires patching the bin right, and then on top of that you need a programmer that's compatible with the NVRAM module - in which case tunerpro is not there yet, and tunercat is out for good ?
It seems like a really good future possibility. I'm looking forward to your progress. I'm using the $60 mask right now, ostrich, and tunercat.
-- Joe
Old Apr 7, 2008 | 08:54 AM
ty1295's Avatar
$58 based code won't work with this yet. It is on our list with code59 to make happen and I know Dig tried it some. GM left some things to be desired and the ALDL communication stuff in $58 based chips is one of them and made it obvious to make work is more than just moving some data around in the chip, but a rewrite of some or most of that communcation routine.
Old Apr 7, 2008 | 10:58 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ahh well
Maybe one day.
-- Joe
Old Aug 7, 2009 | 01:32 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
any progress with the nvsram and code 59? I've been away for a while and may have missed news about this.
Old Nov 18, 2009 | 09:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
BUMP.. im headed over to $59 to look for info but its down just like TGO is lately.
InfernalVortex
Apr 20, 2021 11:31 AM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
RedLeader289
Sep 23, 2015 06:50 AM
