NVSRAM Help Upload Bin File?
Old May 24, 2008 | 01:34 AM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Anyone here really good with this NVSRAM?
Thanks,
Dave
Old May 24, 2008 | 04:15 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: NVSRAM Help Upload Bin File?
Load the "chip" on the board with the supplied file or the S_AUJP (41026 version) modified to your calibration first.
That will be the default file should the memory onboard get a glitch.
After that yuo just use your fav bin editor and make changes. Save the file with updated checksum (if your program does not do it automatically)
Close the editing program and open the RT4 tools software that MonteCarSlow has created.
There is a link to it in some of the threads concerning the board.
Click upload bin and select the file.
Done.
Old May 24, 2008 | 04:33 PM
drb930's Avatar
Problem is i ordered the chip from Moates with VATS installed.
Changed the bin file, but could not get it to up load with TP.
I downloaded the RT-4, but nothing seemed to work.
Finally i deleted the settings for the aLdu1 and just used the settings that windows wanted to use and the RT-4 uploaded the file.
I still cant get TP to reconize the ALDL?
Guess i need Moates to brun me a bin file that does not have VATS so if the thing chashes the default will be no VATS.
Thanks,
Dave
Old May 24, 2008 | 11:18 PM
drb930's Avatar
Done.
Just to be clear-
1) Am i to understand that the only to load a bin file is with the RT4 tools?
2) The "chip" on the board that i had Moates burn with S_AUJP has the VATS enabled. Should i change that chip to one that does not have the VATS so that will be the default, no VATS in case the on board memory gets a glitch?
3)Is there now a way to load a bin file with Tuner Pro, or RT Tuner, or are they only for modifying the bin file?
4)Also if i have Tuner Pro can i data log through the ALDL?
Thanks,
Dave
Old May 25, 2008 | 12:27 PM
JP86SS's Avatar
Originally Posted by drb930
Just to be clear-
Correct
You should use your "good" starting point bin file on the onboard chip.
It is the "backup" that will be loaded should there be any memory problems.
That is doubtful but is a designed in feature that will keep the system running. I update mine periodically so the best file I have is on there.
If you don't have a VATS box then yes, uncheck VATS in the base chip.
They can only modify the bin. Must use RT4 to upload.
Any logging program will work.
Thanks,
Dave[/quote]
Old May 25, 2008 | 02:09 PM
drb930's Avatar
I think i spent most of last night up for hours reading everything that came up under the NVRSRAM search.
1) It seems to me that some other people are having trouble as i am getting the Tuning Pro to see the ALDL with the NVRSRAM installed, and hence no data log.
2) Monte Car says that we all need the capicator installed, but my kit did not come with 1 for the main chip. Do i need to do this mod?
Thanks for all the help here, i love this site!
Dave
Old May 25, 2008 | 02:41 PM
drb930's Avatar
Is there a way that i can change the program on the base chip through the ALDL, or do i need to have another chip burned without the VATS?
The base chip is the C2 SST 27SF512 Chip from Moates.
Thanks,
Dave
Old Sep 19, 2009 | 12:03 AM
drb930's Avatar
Thanks,
Dave
I never got an answer for this, but still need one?
Do I have to have someone with a "burner" make me a new eprom chip with the VATS "disabled"?
Or is there a way that I change my eprom through the Rtp-4 Tool?
Thanks,
Dave
Old Sep 19, 2009 | 05:14 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
You have to physically burn the chip. It cannot be burned through the ALDL
good luck with it
-jason
Old Sep 19, 2009 | 04:27 PM
syntax terror's Avatar
I think you can use your set up to burn the chip if you put it in the right socket.https://www.thirdgen.org/forums/diy-...k-based-2.html
I could be mistaken
Old Sep 19, 2009 | 05:45 PM
JP86SS's Avatar
There is no way to burn the "base" chip while in the ECM.
Its not really a big problem.
The only time that will reload is on a real bad error or you hit the reset button on the tools app.
Let it load as normal, make a change to the bin you are running and upload it.
The memory bin will allow the car to start.
You should get another burned with VATS out (and your best tune to date) but it won't stop you from driving now.
Old Sep 20, 2009 | 02:16 AM
drb930's Avatar
That's what I thought, need to get a new eprom without the Vats just in case.
I will have Craig at Moates burn me 1 with the current program.
Thanks,
Dave
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
school boy
Oct 22, 2015 11:47 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
pacoelrapido
Sep 11, 2015 02:41 PM
