730 ECM conversion dwell time
Old Jul 9, 2008 | 12:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I was looking through the MAF $6E and the MAP $8D code the other day. I noticed that the coil dwell time appeared to be different. It looks like doing the MAF to MAP ECM swap using the stock MAF dizzy (large cap coil) will not charge (dwell) the coil long enough to saturate / charge it fully.
One more anomaly of doing a MAF to MAP ECM swap.
Old Jul 11, 2008 | 10:12 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Re: 730 ECM conversion dwell time
that's really only the case when using corvette BCC's right? other than the $32 in 85' in camaros and 'birds, they all used the small cap dist as far as I know for $32b and $6e
great detective work, BTW....
Old Jul 11, 2008 | 11:26 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
There are also two different modules and latency tables used with the small cap modules. RBob recently did some testing of them. One of the combinations (048 module) retards the timing steadily over 3,200 rpm. The second (369) held steady until a higher rpm and slowly advanced a total of 2*.
The TPI's and the Fullsize Van TBI motors had the good "369" module and the lower performance cars got the lame one.
Originally Posted by RBob
Have some interesting information to add this this thread.
First item to note is that in the opening post of this thread, the table shown as for AUJP is not. It is the latency table used for AXCN & ANHT. Which are Corvette large cap distributors. The poster in the thread that liquidH8 linked switched the two tables in his post.
AUJP uses table 2 in the following:
Code:
	Table 1	Table 2
RPM	 usec	 usec
6375	137.34	305.2
6000	137.34	305.2
5600	137.34	305.2
5200	137.34	305.2
4800	137.34	305.2
4400	152.6	305.2
4000	152.6	289.94
3600	137.34	320.46
3200	167.86	305.2
2800	183.12	244.16
2400	137.34	274.68
2000	137.34	244.16
1600	106.82	305.2
1200	45.78	274.68
 800	 0	213.64
 400	 0	  0
   0	 0	  0
I have been able to identify two different ignition modules for the small cap distributors. They are the 048 and the 369. Check out the picture of the modules. It is the first 3 digits.
I ran 2 each of the 048 & 369 along with a Holley module through some tests. This was done on a live engine using a marked balancer, timing light, and the What's Up Display to show the commanded SA timing and the engine RPM. The EBL Flash had 5 calibrations banks set up for testing.
Bank 0 was the stock calibration to start up the engine and let it settle in.
The other four banks all had the main & extended timing tables set to 20 BTDC. Temperature comp, PE, launch mode, and whatever else was zero'd out.
Then each of the four banks had different latency tables. Banks 1 & 2 had the two tables shown above. Then banks 3 & 4 had the same tables with the low RPM latency values of 0 filled in with the first value greater then 0 from above it.
Code:
Instead of this:
1600	106.82	305.2
1200	45.78	274.68
 800	 0	213.64
 400	 0	  0
   0	 0	  0
It was:
1600	106.82	305.2
1200	45.78	274.68
 800	45.78	213.64
 400	45.78	213.64
   0	45.78	213.64
The reason for this was that it was found that the at-crank timing dropped off with the stock table values of 0. The was still latency at the low RPM's that needed to be accounted for.
With this change running the RPM from 800 through 3200 had each module with the appropriate table holding a steady SA. Switch the table and the advance moved around as the RPM changed.
The Holley module (part # 891-103) matched table 2. This was from 800 through 3200 RPM. Did not test past this RPM.
You may be thinking that 3200 is a low RPM. However, look at the engines/vehicles the ignition modes are used in. None of these engines are high RPM. Trucks, Vans, TBI 3rd gens, Caprices, Wagons, even the TPI engines aren't high RPM engines. Note what happens in the following tests. . .
Another test: while checking the timing as the RPM was increased, both the 048 & 369 modules held steady until a particular RPM. This was with 048 & table 1, then 369 with table 2.
The 048 module, it held steady timing until about 3800 RPM where it retarded 4 degrees. Then by 5000 RPM the retard had increased to 6 degrees.
The 369 module, it held steady timing until about 3200 where it gained 2 degrees of advance. This held steady to 5000 RPM, which is the highest RPM it was checked at.
If we could get a sampling of the ignition module in various 3rd gen engines it would be helpful. Under the cap check the 3 digit number and post back. Along with whether it is TPI or TBI. If you know the stock BCC that too would be helpful.
Conjecture:
I know that the latest f-body TBI calibrations use table 2. This matches module 369. Same as the AUJP TPI calibration. I wonder if the 048 modules are for performance limiting, and are set up to limit the engine RPM. With the timing retarded, the power drops off, and most people either up-shift or lift.
Where the 369 modules (the ones I have are from 5.7l full size vans) are more performance oriented. What is interesting is that the 369 modules I have are newer then the 048's. Some even look to be replacements (too new for the age of the vehicle). Maybe a GM upgrade?
RBob.
Old Jul 12, 2008 | 06:37 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
This would explain some things on my setup. Going to pull the dizzy tomorrow and see what number is on the module.
Couldn't tell by the writeup but were the tables zero'd out when the test were run to just see what the module does by itself or were the table values active during the runs?
Would the values in table 2 actually keep the 048 module correctly timed (If tweaked correctly) ?
Old Jul 14, 2008 | 07:12 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Which masks? The Corvette $8D used the large cap dizzy.
I wonder how this translates to my setup running $60.. hrmm..
-- Joe
Old Jul 14, 2008 | 11:45 AM
junkcltr's Avatar
Engine: 3xx ci tubo
I was talking about large cap dwell time and small cap dwell time. This is the time the coil is charged up. The only way to truly find what the dwell time should be is to look at the current draw of the coil as it charges and goes into saturation (full charge).
Some are confusing module latency which is a timing advance / retard thing due to the module. Bob found that some small cap modules (7 pin) have more latency or non-linear latency. This has nothing to do with the coil charge time, but will affect the spark timing. There are federal and CA./emissions modules. The part number difference and latency and probably associated with this (emissions).
The only way I see to figure out the latency table for the module is to make a small AC source and trigger the scope/analyzer of this and the module output at all RPMs of interest.
anesthes,
I was refering to the AUJP code. People seem to mostly use the AUJP code when doing the 165 ECM to 730 ECM swap. Not sure about the $60 code. I was told that the $60 was an abandoned project and no one was working it.
Old Jul 14, 2008 | 11:49 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
anesthes,
It is. I'm on the fence. I don't want to buy another map sensor to try the $59 project, but at the same time I'm disgusted with $58/$60. And at even only 6psi boost, I'm afraid if I run $8D and try to add boost fuel with PE it may risk a failure.
But dwell time on the coil isn't really something I had considered in the past, and I wonder what the $58/$60 dwell stuff is like vs what a large cap dizzy code would be. I imagine a sy/ty would be a small cap remote coil..
-- Joe
Old Jul 14, 2008 | 12:13 PM
junkcltr's Avatar
Engine: 3xx ci tubo
-- Joe
I am not sure how the $59 code maps the MAP sensor. In the BAUJP I made it so the MAP sensor conversion table is a table that is in the XDF and can be reprogrammable for any map sensor. The end user uses a vacuum gauge and small air compressor and plots out the MAP sensor vacuum/boost vs output volts. This goes into the table using the XDF. So, any MAP sensor can be used. Hopefully, the $59 code is like this.
Do not run the $8D with boost. You can fudge the fuel with PE, but there isn't anything that can be done with spark. HHhhmm, I never looked what would happen with the stock $8D and (small) negative PE spark values......do the two's comp. turn into big positive values?
Actually, with a supercharger at 6 PSI using PE fuel and the RPM spark tables wouldn't be "that bad" if starting out on the conservative side. My "don't run $8D with boost" probably comes from my last tuning project with a truck that would make 8PSI of boost (turbo) at 2800 RPM with 25% throttle. $8D would NEVER work with that setup.
Old Jul 14, 2008 | 12:40 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well I've never taken advantage of the extended spark tables on any of the 2-bar masks. I've always locked my advance in to the max I planned on running. Say for example, I could get away with 25 degrees at 10psi, but only 20 degrees at 15psi. I found the combos ran faster without hickups if I just locked in 20 degrees by 3k. When I tried retarding as boost went up it almost always lead to problems.
6psi is at like 6,000 RPM with my powerdyne. It really is a little blower. I was playing yesterday and only got the needle to dance a little into boost (1-2psi) at around 3k in 2nd gear. Same blower might get like 10psi on a small stock 302 but on my 358 with good heads and miniram it doesn't seem to make much boost.
-- Joe
Old Jul 14, 2008 | 01:00 PM
junkcltr's Avatar
Engine: 3xx ci tubo
You are lucky. The TPI engine with the stock cam I tuned ended up with a spark curve that looked like the inverse of the fuel curve (engine VE) when it was under boost. The TPI high VE around 3000 RPM was a pain to tune boost spark. I also mess with spark due to the water/alky pulsewidth so things start becoming quite dynamic in that RPM range.
-- Joe
That is a "high-revver" to me. I wonder if it would work with the stock $8D tables or require the SAUJP extended tables. How much is the VE changing about 5200 RPM?
Old Jul 14, 2008 | 01:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
May I ask what these differences are? It would be good for everyone to know.
RBob.
Old Jul 14, 2008 | 01:40 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I wish I new exactly. I would post the difference, but I am still investigating at this point. It looks like the small cap uses a shorter dwell time but I can't say for 100% right yet. I figure I would post it in case any one else was playing with $8D spark stuff.
If the small cap shorter dwell time is true then it would also lead to "nosing over" at higher RPM like the module spark latency thing you found with one dizzy module.
Old Jul 14, 2008 | 01:56 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I think AXCN is a commented $8D corvette hac, I wonder what the numbers look like compared to AUJP and the earlier MAF code?
-- Joe
Old Jul 14, 2008 | 02:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
-- Joe
I don't see any differences between ARAP [$6E], AUJP [$8D], AXCN [$8D], & ANLU [$61].
RBob.
Old Jul 14, 2008 | 02:11 PM
junkcltr's Avatar
Engine: 3xx ci tubo
RBob.
I found the same thing for AUJP and ARAP. That is, no differences. I think I am wrong in terms of the dwell time change between the large and small dizzy coils. They look to be the same amount of time.
Old Jul 14, 2008 | 02:38 PM
junkcltr's Avatar
Engine: 3xx ci tubo
An interesting tidbit from the Megasquirt.info site
"For example, the older 7-pin HEI coil uses 3.5 milliseconds dwell, the newer 8-pin HEI external coil uses 2.5 milliseconds of dwell. Note that times longer than 4.0 milliseconds would mean the dwell is being reduced at as little as 2500 rpm, meaning longer dwell settings won't make the spark 'hotter'."
I can't find the source where they did the small cap external coil testing.
Old Jul 14, 2008 | 03:06 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I had a conversation with Sofa about a year ago regarding dizzys. I noticed that some aftermarket coils were for mid 70s to late 70s, late 70s to early 80s, and mid 80s to like '90 corvette. I didn't 'get it' because the coils were the same size (large cap), same number of wires, etc. However the wire colors were different and the aftermarket mentioned this. I asked Sofa his thoughts and he felt it had to do with differences in coil dwell time over the years. I happen to be running a coil part # out of a '79 pickup in my '87 vette right now, with no (that I know of) ill effect but its always made me wonder. Perhaps you are on to something.
-- Joe
Old Jul 14, 2008 | 03:55 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Over the years the push has been to make coils that charge faster due to higher revving engines. A typical large cap wants 3.45msec to charge. A V8 at 6000 RPM only allows 2.5 msec charge time. The small cap coil at 2.5msec seems like a better fit. Aftermarket coils usually have a lower resistance to charge faster. Of course, more heat is made in the coil.
Both the ARAP (big cap) and AUJP (small cap) seem to have the dwell set for 3.5ms.........which comes out to about 4,300 RPM on a V8. If the small cap only needed 2.5msec then there is no worry about misfiring at 6000 RPM. The large cap would seem to be erratic at that RPM.
I sent you a PM about your SC and how to not go lean at non-WOT under boost using PE MODE with the $8D code. You can change the MAP threshold (AUJP uses it as a vacuum KPA) at 0xL85FF and TPS threshold tables at 0xL8603 and 0xL8608 for entering PE MODE. I would make it come in earlier. I would also zero out the PE MODE spark advance for your engine.
EDIT: I would make one test run with the $58 first and find where the minimum TPS is where you can make boost. Then I would reduce those values by 5 - 10% and put them into the TPS tables above. I would make the PE MODE fuel mult. rather large and then test slowing rolling into the throttle with the $8D and see that the PE MODE mult. is applied as you expected.
Old Jul 14, 2008 | 07:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Coil charge time is determined by the inductance, not the resistance. Or more accurately by the reactance of the coil windings. Which also defines how quickly the energy is delivered to the spark plug.
Note that the ECM calculation includes a dynamic dwell calculation. They just don't dwell the coil as long as possible all of the time.
For the higher rev'ing engines GM's answer is CnP setups.
RBob.
Old Jul 15, 2008 | 10:56 AM
junkcltr's Avatar
Engine: 3xx ci tubo
RBob.
We both know the charge time is from the inductance AND resistance of the coil. Yes, both the reactance of the winding (jwL) and the resistance of the wire itself. All trivial electronics. As for the energy delivered to the plug...we both know it is a lot more than the coil (rotor/cap spark gap, plug wire, plug, etc).
I was looking at the dynamic calcs. It still looks like the small cap got 3.49 msec for a max. (desired) charge time for max. energy at higher rpms. When time ran out, the ECM reduces the dwell time because it has to..........but the small cap appears to need only 2.5 ms when the large cap appears to need 3.5ms. In other words, the small cap is inherently designed to work properly up to 6,000 RPM on a V8 with the ECM. The large cap is inherently designed to work properly up to 4,300 RPM on a V8 with the ECM.
Oh yeah, one other thing is the current limiting of the module. That comes into play also for the energy delivered. Of the two small cap modules you tested.......did they both have the same current limiting?
Vizard did some testing with the large cap coils and they seemed to start to misfire at 4,500 RPM on a V8 with stock modules. Aftermarket modules with a high current limit extended the RPM range (more heat/energy in the coil too).
Simply more coils will cure the dwell time problem. That is how the bikes have dealt with this for years (15,000 RPM). Coil on plug is the way to go because of no worn out parts.
Old Jul 15, 2008 | 12:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the inductance being the major contributor to charge time.
It appears that you still believe there is a difference between the small cap and large cap dwell calculations. $6E vs $8D, of which $8D is used on both small cap & large cap applications. Can you point out the differences so that we all know what they are?
What have you measured the coil charge times at? This is an important factor in when the current limiting comes into affect.
RBob.
Old Jul 15, 2008 | 12:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Yes.
No, ECM calcs are the same. Coil characteristics are different. Small cap coil appears to be superior.
RBob.
No. Yes.
Old Jul 21, 2008 | 11:55 AM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
So would you guys say that the MAF setups ran the large caps with the 048 modules cause of the RPM limits they wanted to impose?
and that the MAP based stuff uses a small cap with a 369 to make it have more power up top?
This is a very interesting thread for me. What if there was a way to make an external IM controller that you could adjust the charge time? It would be easy to make a circuit to intercept the ignition module pulse, add a fixed on (charge) time, and then send it down to the coil? If I'm correct, then the on time of the coil is independant of the rpm. It would again be easy to make the controller have a trim pot to adjust the on time. That way you could adjust it depending on what coil you are running. Similar to points adjustment.
Old Jul 21, 2008 | 11:56 AM
jwscab's Avatar
Engine: Many
these 2 modules are for the small cap only. It would be interesting to see how the large cap modules behave.
Old Jul 21, 2008 | 12:51 PM
junkcltr's Avatar
Engine: 3xx ci tubo
You are confusing dwell time with module DRP latency.
No need for extra hardware. The stock ECM code appears to be optimal for the stock coil. If you had a better coil then you could change the code to use constants, but then you wouldn't gain much because of the stock module current limiting.
Weather you run electronic ign. or points...........you still run out of time at high RPM with only one coil. You can only set the dwell as high as you have time to fire a plug.
Old Jul 21, 2008 | 12:54 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Assuming the $6E and $8D tables are correct in the code....................see this thread showing how the latency would change the spark advance using the $8D code with a stock large cap $6E module.
https://www.thirdgen.org/forums/diy-...t=#post3810919
Post # 31
Old Jul 21, 2008 | 01:54 PM
jwscab's Avatar
Engine: Many
Hey Junk, I know it's a nitpick, and I brought this up already, but you've mentioned a couple times the 'MAF code' as a large cap, which isn't always the case. For instance, my '87 IROC is a MAF, yet uses the small cap. Just wanted to clarify for anyone not as closely familiar with this stuff that might be reading.
it may be from your investigation that ALL the maf code (32B, 6E) might well be using a 'large cap' value while using the small cap hardware in certain instances.
Old Jul 21, 2008 | 02:08 PM
Blue1989RS's Avatar
Car: 1989 RS
I think I'm understanding a little better now. So it basically has to do with the coil and module charge times and how they peel back the advance to make you shift before the spark piddles out due to not enough time to charge the coil.
I can see now that if someone was running a new coil with the old code how it would make little difference. You would need to update the constant in the code to decrease the charge time to take advantage of the new coil. But at the same time you should update your ICM so its not retarding. Am I getting this right?
Are the LT1's any different for this? I know they ran the optispark to stabilize the cam position signal, but mine ran what appeared to be the same coil with an external module. Mine had a factory fuel cut at 5800 so it might be the same thing with the coil charge time.
Old Jul 21, 2008 | 02:19 PM
junkcltr's Avatar
Engine: 3xx ci tubo
You are right. It is good you mention that. For some reason I keep saying large cap is MAF, but that is not the case. Large cap coil was only for 1985-86 years that would be associated with the 1985 code/ecm ('870 ECM, forget the mask) and the 165 ECM with $32 code.
89GTAOz
May 16, 2020 09:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
stalkier
Aug 13, 2015 12:59 PM
