$6E WOT TPS Heads up
Old Jul 26, 2008 | 05:19 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Helping a guy tune his car we found out that at WOT it went out of PE mode and went lean.
The base bin was ARAP and looking in the code there is a Code 21 Threshold at 4.8 v, when TPS reach 4.8 the commanded AFR went back to 14.7 and the car went lean. Also after a while (3s) Code 21 came.
Location in is ARAP 1F2
Dont have any car with 6E code at home right now so I cant test it more with my Ostrich. But the guy I'm helping tried to lower it to 4.0 v and above 4v the desired AFR went to 14.7
/N.
Old Jul 26, 2008 | 08:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $6E WOT TPS Heads up
Yep, on the MAF setups the TPS adjustment is critical. The $32 code will do the same thing, drop out of PE if the TPS goes too high.
Have to watch out for that.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
