NOOB needs opinions
Old Sep 6, 2008 | 03:30 PM
Railguy's Avatar
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
NOOB needs opinions
Hi All ,
im totally blown away by the wealth of knowledge here its amazing!
2 weeks ago i would have been happy too buy a cookie cutter chip and try too make due.
after reading all the stickys primers and fyi's im going too burn me own!!
I will only be doing the 165 and 730
could i get some hardware recommendations from you guys ? i see alot of hardware out there and software for that fact,,, but im total noob i suspect you guys know exactly what i need ,,,
id like realtime capability i know alot of these guys hang out here if you guys want too private your answers thats cool too,,
i hope this doesnt fall under referal service if soo geuss it will get deleted
Im rready too buy but i sure cant afford too not be proactive and pull a oops
thanks a million Rail
Old Sep 6, 2008 | 06:12 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: NOOB needs opinions
you've come to the right place.
as you need everything, my vote is for the AutoProm.
the AutoProm does pretty much everything as far as chip tuning goes, it data logs, it burns, it emulates in real time, it slice & dices,... oops, wrong product.
the AutoProm comes with a license for TunerPro which you can download for free.
you'll also need some chips & adapters for your applications.
the AutoProm, chips & adapters, http://www.moates.net/
TunerPro, http://www.tunerpro.net/
also, a wideband O2 sensor isn't mandatory, but it can really help make tuning much easier.
good luck
Old Sep 6, 2008 | 06:17 PM
Railguy's Avatar
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
wooot TY and there's nothing wrong with Julienne fries either
thanks Rail
Old Sep 6, 2008 | 07:05 PM
Railguy's Avatar
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
please guys i really need input here ,,,autoprom it is for sure g2 adapter im assuming,,,software: tuner pro,,,, will get wideband o2 also wondering about 5 wire searching like a freak for interface/application ,,,oh no another PITA noob
rail
Old Sep 6, 2008 | 09:35 PM
DENN_SHAH's Avatar
i can't help you on the 165. but for the 730, the G1 is what you need.
or you can get the G3 or the GP3 & a couple of extra 29F040 chips. like this you can burn up to 16 bins to the chip using the bin stacker in TunerPro. then using the G3 or the GP3, you can switch between the bins.
if the adapter you get doesn't come with one, a ZIF is well worth the price.
i may have not worded it right on the wideband O2 sensor, you'll need the controller too. the wideband O2 sensor alone won't work.
there are a number of wideband O2 sensor kits available. Craig Moates sells the Innovate which a lot of people here have.
http://www.moates.net/product_info.p...products_id=88
i have the Zeitronix ZT2,
http://www.zeitronix.com/Products/zt2/zt2.htm
on the 7730 ECM, using either the Innovate or the Zeitronix, you can modify the ECM and then input the wideband output into the ECM & log it in TunerPro. you'll need use S_AUJP_V4.
there is also a patch to data log the wideband in TunerPro if you want to use your stock bin. but with the better resolution that V4 has, i feel its the bin to use for the 90~92 TPI SD systems.
i should mention, S_AUJP_V4 may be a bit much for you just starting out, but it is definitely worth looking into.
Old Sep 8, 2008 | 04:08 PM
Railguy's Avatar
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
OK bought the pocket programmer 2, the romulator ,25 27c128's,
the LM2 wideband system ,tunercat ,tunerpro,,and $32 and $32b
anyone see anything i missed
thanks Rail
Old Sep 8, 2008 | 04:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Will need 27C256's for the '7730 ECM. The '128s will work with the '7165 ECM.
RBob.
Old Sep 8, 2008 | 04:24 PM
Railguy's Avatar
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
Thanks Rbob ya i got the 128's for a smoking deal they are not OTP
i also got the g3 and switch box ,,,well ordering it in a second now that craig is back up
im gonna bin stack it,, lets see if i could just buy skill now..........
Rail
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
