Tried everything I can think of- can't stop knock retard - looking for ideas
Old Oct 20, 2008 | 08:07 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
Hi - I have an 89 GTA 5.7 TPI. I installed vortec heads, sd vortec intake, edelbrock headers. ZZ4 cam. All smog stuff intact.
When I went to start tuning I couldn't stop getting knock retard. I am back to the stock prom (ajup). Base timing is 8 degrees. I kept adding to the base timing in the prom until I took out whole 14 degrees of advance - I still get knock. I started adding fuel and doing runs. I have a wideband and I am running close to 11:1 at WOT. Still knocking. I ran a dedicated wire from the knock sensor to the esc module and a dedicated ground to the module. Same results. Also replaced the knock sensor. No difference.
Here's a log if anyone can check it out and give me pointers:
http://members.bellatlantic.net/dantill/rewire.csv
thanks in advance for any tips - I've been at this a long time and I am very eager to figure this one out!
Old Oct 20, 2008 | 09:39 PM
18436572's Avatar
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
Axle/Gears: 4.88 full spool
Re: Tried everything I can think of- can't stop knock retard - looking for ideas
Maybe verify the timing with an advance timing light.
Old Oct 20, 2008 | 10:47 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You can't log using the $32 DM if you have a 730 running $8D.
Try logging with the $8D version or otherwise change to a MAF memcal/bin.
AUJP is $8D (SD, not MAF)
I'm confused, what is your setup
Old Oct 21, 2008 | 06:00 AM
Car: 89 GTA
Transmission: 7004R
I am running MAF - I will double check tonight but I am sure I'm running the right memcal - I just got the names mixed up in the message. I have the "165" type computer. I was running with arap before but I switched back to stock and dialed back when I was getting knock.
Old Oct 21, 2008 | 06:05 AM
Car: 89 GTA
Transmission: 7004R
Other thoughts - I hear no pinging/knock, and the car runs great with arap other than the knock. With all the timing removed not very responsive (base timing in PROM at about 22 deg), so I know that's working. I did have the cam, heads and intake off, and I am an amateur, so maybe I did something to throw off where the timing mark is?
Old Oct 21, 2008 | 06:58 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
When you check the base timing, you are disconnecting the EST wire correct?
-jason
Old Oct 21, 2008 | 07:08 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
You're sure there's no mechanical issues? No loose rockers or worn bearings? I've even heard of worn valve guides causing a sound that the KS might pick up as knock.
Old Oct 21, 2008 | 07:31 AM
Car: 89 GTA
Transmission: 7004R
Originally Posted by Six_Shooter
You're sure there's no mechanical issues? No loose rockers or worn bearings? I've even heard of worn valve guides causing a sound that the KS might pick up and knock.
I will consider that as a possiblity.
Engine has 55k original miles, L98. Heads are new Vortec. Burns no oil or anything. Knocking starts when I floor it.
I remember following a procedure in the manual for torquing the rockers, they seemed pretty tight.
Old Oct 21, 2008 | 09:57 AM
Car: 89 GTA
Transmission: 7004R
I just read an EGR issue can cause knock.
Can I just diable EGR in the PROM to rule it out as a cause of knock? Also, I have no codes, either.
Old Aug 12, 2009 | 06:01 PM
Car: 89 GTA
Transmission: 7004R
just looking at my old messages - dropping 1 heat range fixed it (R44 to R43 AC plugs)
Old Aug 23, 2009 | 08:32 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
if it runs well and only knocks when you floor it, try taking some timing out of the PE table...
Old Aug 28, 2009 | 03:56 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
If you pulled timing the knock was still there i would say its false. Disable the knock sensor or desensitize it a bit and be done with it.
Old Aug 29, 2009 | 12:55 AM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
How do you do that?
toones
Jan 6, 2016 06:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Thaney9
Aug 29, 2015 03:16 PM
db057
Aug 22, 2015 08:17 PM
