SST chip programming problem
Old Dec 9, 2008 | 04:50 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Hi, I just bought set of SST 27sf512 70ns chips to replace my Atmel At29c256 chips that went bad. I'm using PP2 to program the chips and I changed the voltage to reflect the new SST chip. The chip programmed with no issues but when I install it in the car, it goes into limp home mode. For some reason the 7730 ECM is not accepting the new chip. Did I forget to change a setting somewhere? Thanks for your help.
Old Dec 9, 2008 | 06:23 PM
pwdbychevy's Avatar
Re: SST chip programming problem
I believe I found the solution to my problem. I had the offset wrong for the new chip. Here is the link I found just in case anyone else has the same problem. Worked like a charm.
http://www.moates.net/documentation....entation_id=75
Old Dec 9, 2008 | 06:25 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yeah, theres an offset when using the larger EEPROM's. 8000 for a 32K bin on a 512 EEPROM.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bdads
Aug 24, 2015 06:01 PM
djmarch
Aug 19, 2015 12:07 PM
Sanjay
Aug 12, 2015 03:41 PM
Exxon Limited
Aug 9, 2015 08:13 PM
