Using a T5 with a 2.73 gear. Need VSS help
Old Mar 13, 2009 | 03:21 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Hey all, I'm using a .73 OD T5 trans in my '91 Trans Am with a 2.73 gear. The correct output shaft and VSS gears are not available for this combination, so I am going to have to modify the VSS signal somehow.
I have been reading up on using a DRAC and it seems like it might work, but I have one question. Most people seem to be using the DRAC when they have a 40 tooth reluctor wheel (40 pulses per rev). Since my VSS is gear driven how will I ever find out which DRAC jumper setting will work for me? The input ratio calculations do not account for a gear driven VSS.
Is the DRAC right for me? Are there other options? Thanks for the help guys.
Old Mar 13, 2009 | 03:55 PM
tequilaboy's Avatar
Re: Using a T5 with a 2.73 gear. Need VSS help
17/35, 17/37, 18/40 or 19/42 gears should be close. What size tire?
Old Mar 13, 2009 | 05:29 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I dont have the ~2" speedo gear. i have the 7/8" speedo gear. So I'd need the red 9 tooth drive gear with a 19 tooth driven gear which is not offered. I contacted these guys about it today
http://www.transmissioncenter.org/GM...eter_Gears.htm
They recommended this...
http://www.transmissioncenter.net/sp...n_______va.htm
It is a $169 pulse modifier. I'm sure I can do the DRAC cheaper, assuming I can make it work with my current speedo gears....
EDIT: my tire size is 26.6" dia.
Old Mar 13, 2009 | 07:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A DRAC won't work unless your setup is close to a 40 pulse per driveshaft revolution. A 2K PPM or 4K PPM won't work with a DRAC.
RBob.
Old Mar 13, 2009 | 07:48 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
After I had searched for a while and started to learn a bit, thats what I was afraid of. Thanks for clearing it up for me RBob. And by the way, I sincerely appreciate your input. I don't think people say that enough around here. Guys like you are what have made this site one of the best information sources on the web. I appreciate your time, and your knowledge.
Looks like I'll be using a Dakota Digital box to correct this issue unless someone has a better idea.
Old Mar 17, 2009 | 12:43 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I use a digital dakota to replace the yellow buffer box used to split the vss to the ecm, cruise and speedo.
Check out other post:
https://www.thirdgen.org/forums/diy-...ml#post4031998
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
