LM2 RPM hookup? please HELP!!!
Old Mar 31, 2009 | 06:37 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hello
ive recently purchased the dual LM 2 kit from innovate motorsports.
i do not have an MSD box.. im running pretty much stock ignition.
how do i get this to read RPMS.. it says i can hook up to thge negative side of an injector wire.. will this work??.. id like to know about a prooved procedure before i cut into any wires..
Please help me out
Lee
Old Apr 1, 2009 | 06:28 AM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: LM2 RPM hookup? please HELP!!!
i cant be the only person who has had this problem.. anyone?
Old Apr 12, 2009 | 07:56 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Why would you not hook it up to the coil neg as also suggested ?
Old Apr 13, 2009 | 11:44 AM
Ronny's Avatar
Mine is coil negative.
Old Apr 15, 2009 | 06:14 PM
???'s Avatar
i don't think many people have the lm2 yet. and from what i've read, i decided not to trade my lm1 for the lm2 since the rpm's wasn't all that yet.
for my lm1 with the rpm cable. i used the wire that goes from the icm in the bottom of the dizzy to the ecm. the neg side of the coil gave my crazy noise. this low voltage signal is very clean on my setup. i just tapped into the wire inside where it runs into the ecm.
Old Apr 16, 2009 | 09:12 AM
Ronny's Avatar
Mine signal was funky too until I built what I believe is called a potentiometer(spell?). That cleaned it up nicely. Innovate never suggested using the lead to ECM? I wonder if that has any issues?
Old Apr 16, 2009 | 08:19 PM
???'s Avatar
i built that little resistor thing too. it make the rpm graph usable. but still wasn't very clean.
this is pretty good.
Old Apr 16, 2010 | 10:59 AM
Car: 1989 IROC-Z
Engine: 346 LS6
where might find the instructions for this device?
also, any idea where to attach the rpm on an LS1?
Lee
Old Apr 16, 2010 | 11:36 AM
Ronny's Avatar
http://www.innovatemotorsports.com/s...MA2_Manual.pdf
http://www.innovatemotorsports.com/s...L32_Manual.pdf
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
