Tunerpro V5 update
Old Jan 30, 2010 | 02:07 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Tunerpro V5 update
everytime i open the new V5 it gives me a error message about I0.SYS.login, or something. Also cannot get the new V5 to notice my cable. This is with the 5143 version. Tried to update to the new 5150 version but i click yes to download and then nothing happens and i can't close tuner pro. please help thanks.
Old Jan 31, 2010 | 01:49 PM
trueburton's Avatar
Re: Tunerpro V5 update
well i simply uninstalled the older version and reinstalled the new one and now it works but still won't initiate my cable.
Old Jan 31, 2010 | 03:32 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
If you're trying to "initiate" the ALDL cable, that won't work. The "initiate attached hardware" is for emulation devices not datalogging cables.
To use the datalogging cable, you need to set that up in preferences, com port, type of cable, etc.
Old Jan 31, 2010 | 04:30 PM
trueburton's Avatar
yeah i just figured that out...I also read that i need to load an ADX file before i can read the ECM. is that right?
Old Jan 31, 2010 | 04:36 PM
That is correct.
Old Jan 31, 2010 | 05:09 PM
trueburton's Avatar
well problem solved i logged for the first time today. thanks for the help. I'll post a new thread on my new log next my O2 counts are all over the place.
Old Feb 7, 2010 | 03:04 PM
mrlipps's Avatar
Car: 1990 GTA
Engine: L98 350 Dart Heads 268XFI Super Ram
Transmission: WC T5 Hurst Shifter
Axle/Gears: 3.42 Posi
hey Six shooter
I can't find the com port setting in V5, Its not under tools/Preferences like it was in V4.14, or am I just blind?
Old Feb 7, 2010 | 04:22 PM
trueburton's Avatar
yes it;s under tools>preferences. Then click the data acquisition tab then click the plug-in device button.
Old Feb 7, 2010 | 08:58 PM
mrlipps's Avatar
Car: 1990 GTA
That worked perfect
When I exit out of the program and it asks me to save the Bin, XDF and ADX files, I always just save the bin. Should I be saving the XDF and ADX also? Am I changing something in those when I make changes to the bin?
Old Feb 8, 2010 | 05:20 PM
trueburton's Avatar
as far as i know the ADX and XDF shouldn't change. But i am just starting to learn this stuff too.
junkcltr
26
Jan 22, 2022 10:53 AM
anesthes
34
Apr 14, 2006 12:56 PM
Mangus
18
May 15, 2004 05:13 AM
Mangus
Jan 28, 2004 12:15 PM
Mangus
36
Jan 11, 2004 06:35 PM
