'165 5.0 Manual prom
Old Feb 18, 2010 | 02:14 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
can anybody give me a code (or link) for prom for 5 liter engine with manual trans, it tried to search for it but found nothing
best regards
Old Feb 27, 2010 | 01:33 PM
WASyL's Avatar
Re: '165 5.0 Manual prom
ok, another way round, AXXD is 8D def, but i need prom for TPI manual car with '165 ECM useing 32B def. can anybody give my prome code for such prom or can i use 8D on '165 ECM ?? i tried to search but found nothing, please help as i just swaped to t-56 and cannot run car properly and tuning auto prom to amnual is useless
best regards
Old Feb 27, 2010 | 04:14 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
if 32B is 87-88 then ACYB, ACYC and AKFT are 5.0/5 speed F-cars that you should be able to start with.
Old Feb 27, 2010 | 08:16 PM
WASyL's Avatar
thank you so much
best regards
Old Mar 14, 2010 | 09:01 PM
92 Vert T/A's Avatar
Car: 87 GTA
Engine: 385 Stroker
Axle/Gears: 3.45 9 bolt
My 87 GTA is a 305 5spd, the code is ACYA. I have been looking for the stock bin file for this on the net, but can't find it anywhere. Hope that helps, and if anyone has this bin file, I would greatly appreciate it. I have a socketed cal pack for an 89 model, but would like to start with the same code.
Old Mar 15, 2010 | 05:21 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi,
The original BIN for my car is the ACYC version.
Please let me know if you are interested.
Best Regards,
Bruce
Old Mar 15, 2010 | 07:13 AM
Car: 87 GTA
Engine: 385 Stroker
Originally Posted by BWilcox
Hi,
Best Regards,
Bruce
Yes, if you don't mind, I would like to have a copy of it.
Very much appreciated!
Old Mar 15, 2010 | 01:14 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Hi 92 VERT T/A,
No problem. When I get home from work, I can send you the BIN.
Best Regards,
Bruce
Old Mar 18, 2010 | 12:35 PM
Car: 87 GTA
Engine: 385 Stroker
I found the ACYC bin on Moates' site.
thanks
Chris
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
69GTOby
Apr 18, 2016 02:34 PM
sreZ28
Oct 22, 2015 08:21 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
