hypertech burn?
Old Mar 9, 2010 | 12:13 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
hypertech burn?
I just got a 89 tpi ecm that came with a hypertech chip and i wanted to know if i can burn over the aftermarket chip or if im better off finding a stock memcal to use?
Old Mar 9, 2010 | 05:25 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Re: hypertech burn?
Really... nobody knows?
Old Mar 9, 2010 | 05:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: hypertech burn?
Well, it depends. If the chip has a ceramic body with a quartz window, then yes, it can be erased via UV-A and re-burned. If it has a plastic body and is a flash type chip, then yes, it can be re-flashed. If it has a plastic body and is a OTP, then no, it stays that way. Although (see, didn't I say it depends), if it is really a OTP EPROM in a plastic body, not a fusible link device, it can be erased via x-rays and re-burned.
RBob.
Old Mar 9, 2010 | 09:06 PM
J_D_'s Avatar
Re: hypertech burn?
I popped the Hyper chip out and put a eeprom from Moates in the Hyper memcal.
Old Mar 10, 2010 | 11:43 AM
Ronny's Avatar
Re: hypertech burn?
Would not Hyper lock that chip as proprietary?
Old Mar 10, 2010 | 02:20 PM
J_D_'s Avatar
Re: hypertech burn?
I was able to read the bin off mine. Memcal was actually for an 86 but I use it on an 87.
Old Mar 10, 2010 | 07:39 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
Re: hypertech burn?
nope read mine too. mine had a uv window to reprogram if wanted. but why when eeproms are cheap?
Old Mar 11, 2010 | 03:12 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Re: hypertech burn?
Thanks very much guys... anyone looking for a 89 tpi 350 auto chip?
Old May 4, 2010 | 12:08 AM
unscarredcfh's Avatar
Car: 89 GTA
Engine: L98 5.7 TPI
Axle/Gears: BW 9 bolt 3:45
Re: hypertech burn?
which chip and how much
Old May 9, 2010 | 08:18 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Re: hypertech burn?
Sorry its sold.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
KO1
16
Oct 15, 2015 05:00 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
