aldl data tracing
Car: 87 ls1 camaro 510 rwhp
Engine: 2002 ls1 cam carb and juice
Axle/Gears: 4.10
aldl data tracing
quick question does the aldl data tracing in the toolbar mean that during data logging it brings up a highlighted window in the graphs you are working with as to where u are currently during the data logging like more common tuning software? maybe a dumb question but didnt want to hit it if it wasnt what i thought
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: aldl data tracing
once you have setup the ALDL Association, yes, it does highlight where you are in the table both during data logging and when playing back a data log.
if you haven't setup the ALDL Association, then it does nothing.
i think this should get you going,
https://www.thirdgen.org/forums/diy-...tatracing.html
after you get it setup and when you close TunerPro, it will ask if you want to save the changes, tell it yes.
after that Data Tracing should work every time you start up TunerPro and hit the DT button.
Elephantismo
Feb 13, 2019 12:51 AM
gta892000
Sep 16, 2015 12:37 AM
