help datalogging tunerpro v5
Old Oct 15, 2010 | 12:58 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Im new to this and when I go to the aldl values screen I only get a few readings under a header that says general. How can I get more to show like I've seen in screen shots. Also I have heard I am supposed to tune in open loop but cant find where I increase the temp so It wont go into closed loop.
Old Oct 18, 2010 | 05:48 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: help datalogging tunerpro v5
What mask file are you running? 32? 32B? 6E?
Old Oct 18, 2010 | 09:44 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
If you're referring to your 1987 TPI, then you "should" have a $32B code mask. Sounds like, from what little you have told us, that you have a bad or wrong definition. Try going to Tunperpro's website and re-downloading the correct 32B file, and let us know how it goes.
Old Oct 19, 2010 | 03:54 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
I started with 32b but then switched to 6e and ive got everything now. is It a problem that my bin is a 32b and I datalog with a 6e definition.
Old Oct 20, 2010 | 10:00 AM
Tpx's Avatar
Tpx
If you are asking if it is a problem, yes that is a problem. You must have a 32B bin with 32B definition, get a 6E bin with 6E definition (I did the exact same switch myself) and just copy over all the tables, or hand edit them to what you had on the 32B code. OR, you could just start fresh and tune your engine from a stock 6E bin. Your call, but you can't mix and match bins/definitions. If you want a nice dash setup (for tunerpro 5) for that 6E definition just let me know
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
tmellott89
Aug 16, 2015 02:58 PM
