SPIKE in spark advance
Old Jan 27, 2011 | 12:35 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
While datalogging, and with the set timing bypass connector disconected, the "Spark Advance relative to Reference pulses" jumps from 2.11 (normal; from spark table) to 23036.17(infinity) back and forth, gets more frequent with higher temperature. what does it mean????? Brand new ACDelco coil and ICM.....
Old Jan 27, 2011 | 10:19 AM
EagleMark's Avatar
Re: SPIKE in spark advance
I'm not sure and my test bench is down so I can't try to duplicate it right now... But why datalog in bypass? What is the timing doing with timing wire hooked up.
Going up with heat makes me think you did not use heat disapation grease under the ICM (EST), your talking about the module in the distributor correct? It needs the heat disapation grease or it'll over heat and die...
Old Jan 27, 2011 | 12:42 PM
boldguy's Avatar
Car: 1992 Z28
You know what when i was running with it hooked up it was doing the same thing i was just seeing if it would do the same thing if the bypass was connected. I had the mechanic put the ICM and Coil and those fuggers better hope they installed it with that heat sink compound i gave them. I'll have a look see.
Old Jan 27, 2011 | 01:34 PM
boldguy's Avatar
Car: 1992 Z28
Check the image...
Attached Thumbnails SPIKE in spark advance-screenshot-spark-adv-rel
Old Jan 27, 2011 | 04:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by boldguy
Check the image...
The spark advance is going negative relative to the reference pulse and the conversion for it isn't correct. It is a signed value which is being treated as un-signed.
RBob.
Old Feb 2, 2011 | 02:39 PM
boldguy's Avatar
Car: 1992 Z28
Rob, so do you think its only a matter of correcting a typo in the bin (add a negative sign)?
Do you know where I should look in TunerPro to find this one?
Old Feb 2, 2011 | 04:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The change needs to be made to the ADS file. Which is the data stream definition file.
RBob.
Old Feb 2, 2011 | 04:44 PM
boldguy's Avatar
Car: 1992 Z28
Sorry for sounding like a noob, but what do I do from here? Thanks Rob for all the help, you really know your shidt
Old Feb 2, 2011 | 05:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I don't see how you can do it. Would need the 'signed' value check box. This is included in the calibration's XDF file editor but not here. Need to be aware of what the reporting is doing.
And when it jumps it means that the timing is less then the base setting.
RBob.
Old Feb 2, 2011 | 06:18 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Not sure what version you have, Get the updated TunerPro version.
There is a check box for "signed" values in the ADX file editor.
Old Feb 2, 2011 | 07:42 PM
boldguy's Avatar
Car: 1992 Z28
So basically the values (infinity) should be a negative number instead? Makes sense. I'll check it out. Also I noticed my iac steps were between 1 and 5 as soon as it warmed up. Is there any other possible cause other than a vacuum leak? My map was at almost 20 kpa...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Jorlain
Oct 8, 2015 01:57 AM
Jlanz55
Sep 9, 2015 09:09 AM
