24* Initial Timing - Time to Learn How to PROM?
1 Post
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Just finished tuning the beast, and I am confused. I got startling backfire and crappy idle until I advanced all the way to what I guess is 24*. Now she runs great. This number is absurd, as I understand.
I have no idea what's in this motor. The kid I bought it from didn't seem to know what he was talking about. There was an alleged rebuild a few thousand miles ago. TPI is stock, fuel system is stock, heads are stock. Has headers. Sure feels like there's a bigger than stock cam in there, but I wouldn't know how to be sure. Those are the only two upgrades unless you count msd wires and smog and ac delete. Would a cam alone warrant PROM tuning? I just can't imagine why she would want so much initial advance.
Or is it possible something was put in wrong? Could the pulley be lying?
1 Post
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Re: 24* Initial Timing - Time to Learn How to PROM?
OR...could there be a totally inappropriate chip in there? I don't even know where the ECM is mounted, but I'll look into getting equipment to read it.
Car: check
Engine: check
Transmission: check
Get the three or four letter code off of the MEMCAL. See the sticky's on the DFI & ECM board here at TGO for pictures of that.
As for the 24* initial, is that BTDC or ATDC?
RBob.
1 Post
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
BTDC
Bingo! Reman ECM. Though I'm not seeing the MEMCAL. Perhaps it's under this removable plate...
1 Post
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Now to find out what this means. And how to change it.
In case you can't quite read it: Delco ACXT 1099. The sticker says "Calibration Code: 0301MG" if that means anything.
Also, it says "Number: 7-7165." I'm going to assume this identifies it as a "165" for short?
According to other posts, this is the correct computer for this car. Does that rule it out as the source of my seemingly outrageous timing?
1 Post
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Yes and yes. It's currently set about the length of the tab behind the tab. When I started the timing session, it was so far back I could barely see it. Probably at about 11 o'clock.
1 Post
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
That's what I was thinking at first, since the car has had some hack work done on it before I got it. But no, the real solution was much simpler than this. I've been playing with Camaros since 2003 when I got my license, and apparently I've been unplugging the EGR to set my timing this whole time. Suddenly the world makes sense, and I am pretty thoroughly embarrassed. Well at least I learned some things about my ECM today.
Since the thread is already here now, what else can I deduce from the numbers on my computer? What does the calibration code mean? Has it been modified already or just replaced, since it does say remanufactured.
Oh also, my scanner says the PROM ID is 801. Stock?
theshackle
09-17-2020 08:26 AM
