ALDL Pinout
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
ALDL Pinout
Hey Guys, Was not sure where to post this but thought in here may be the best.
Does anyone have all the pinout locations for the aldl connector for an 86 Camaro? What I am looking for is where does pin X on the aldl go to.
Car: check
Engine: check
Transmission: check
Re: ALDL Pinout
Assuming this is the stock '86 TPI ECM, pin E is for 160 baud and pin M is for 8192 baud. Will need a 10K across A & B to get the 8192 data stream flowing. It can then be removed.
I don't know if the 10K is required for the 160 baud.
RBob.
RBob.
Car: 86 IROC
Axle/Gears: BW 3.27
Re: ALDL Pinout
I am looking for where pin a-m go to on the ecm and the car. I know a is a ground and b is the diag port that goes to the ecm (cant remember what pin on the ecm at the moment). Where do the rest of them go?
Car: check
Engine: check
Transmission: check
Re: ALDL Pinout
E ECM A8 data
M ECM A8 data
B ECM A9 diag
A ground
G fuel pump relay NC to pump
F ECM A7 TCC
C ECM A2 AIR to Port
RBob.
Car: 86 IROC
Axle/Gears: BW 3.27
Re: ALDL Pinout
Thank you very much, that is what I wanted to know.
Another question for you, E and M, are they linked together somewhere along the harness? or is it right at the ecm?
Car: check
Engine: check
Transmission: check
Car: check
Engine: check
Transmission: check
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: ALDL Pinout
Not to hijack the topic but the topic has somewhat helped me and may somewhat help as far as datalogging. Originally an '88. I upgraded to 8746 ECM. I am working on a conversion to 6395 PCM. I'm working on connecting with it at the moment using TunerProRT.
I'm confused as to why the cable I used with WinALDL at 160 baud will not work at 8192? If in fact the pins are tied together... if not can I an just use the same cable after connecting the two? They are both orange wires. I have a switched 10K resistor tied between A+B for some reason on the connector(I knew the reason about 1-2 years ago).
Car: check
Engine: check
Transmission: check
Car: check
Engine: check
Transmission: check
Re: ALDL Pinout
The TBI set up uses pin E only as it is only 160 baud. Don't need the 10K unless you want to put the ECM into ALDL diag mode.
The TBI ECM always sends data, it is uni-directional. An 8192 baud ALDL is bi-directional. Need to send a request before it will send the scan tool data.
So different levels of cable complexity is required.
RBob.
Engine: 327
Re: ALDL Pinout
Yeah, just saw the DIY schematic for the 8192 baud... guess I'll just buy a cable since making one would be more than it's worth in the end. I feel like I'm 100 years behind as far as techlology goes. Thank for the help.
Car: 86 IROC
Axle/Gears: BW 3.27
Re: ALDL Pinout
Another question. I have tunerpro rt and the xtreme aldl from moates. It seems that I cannot get any data to come through. The serial line is in pin e and I either leave pins a and b open or put a 10k resistor across it and nothing. I also noticed that when i start tunerpro up, it says that there is no hardware found, but I go to preferences to check the hardware and it is there. Any suggestions?
Engine: 327
Re: ALDL Pinout
There is a definition that is needed for connecting to the ECM/PCM. I figured that out the other day after posting on here. I'm not sure exactly where to get them but they have some on the TunerPro site. I just ordered all the parts to make my own 8192 baud interface cable. So I'll have to test my electronics skills and hope it works when i'm done.
Car: 86 IROC
Axle/Gears: BW 3.27
Re: ALDL Pinout
I have the ads file to connect to the ecm. But for some reason it still wont. I posted in here as well https://www.thirdgen.org/forums/diy-...talogging.html That is the exact same issue that I am having.
