$E6 ~ $OE ~ $OD ~ $31 ~ $42 VE Fixer Spread Sheet
Try using the attached Excel spreadsheet for fixing VE tables. The spreadsheet includes the older '7747 $42 and the newer TBI PCM with $OE, $E6, $OD, $31. Copy / Paste the running averages from the TunerPro RT BLM History Tables. Compared to other VE Fixers, the attached spreadsheet is simple to use and will get the VE about 90% ~ 95% accurate. The spreadsheet will work with freeware OpenOffice.org.
dave w
dave w
Re: $E6 ~ $OE ~ $OD ~ $31 ~ $42 VE Fixer Spread Sheet
The spreadsheet does not remove AE / PE or sort Open Loop / Closed Loop data. Before starting the recording of the data log make sure the ECM / PCM is in closed loop. When driving and data logging, try to avoid AE / PE modes.
dave w
dave w
dave w
dave w
Is there something im doing wrong in open office when it asks what to select in this screenshot ?
Car: check
Engine: check
Transmission: check
RBob.
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
does anybody have any good links to any tutorials or how-to's about filtering out the AE PE and OL in either tunerpro or excell ?
I have a couple of $0D projects to tune and a better spreadsheet tuning utility would save some time.
gixxer92
Apr 12, 2022 12:09 AM
gta892000
Sep 16, 2015 12:37 AM
