Tuner Pro speedometer?
Old Dec 1, 2011 | 03:47 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I was having an issue the other day when my laptop died. I had to rest the 7165 definitions as well as the correct com port. After doing that I was able to datalog again. Ever since while car is in park and at an idle my speedometer is jumping around from 0-100mph. This is happening on the cars speedo as well as in the data log. Is it possible that while i was trying to fix TP i clicked on something in the setting that would cause this to happen? Thanks
Update..when I rev the engine the speed seems to follow the tach even though the cars in park
under tools in TunerPro>General>Files Association, I have all the file options checked off. I wasnt sure which files were need but think that could be my issue???
Old Dec 1, 2011 | 04:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tuner Pro speedometer?
That's odd especially in park. while in drive the vss sends a 2ppm to the speed buffer. The speed buffer sends a optical 2ppm signal to the ecm and a 4ppm to the speedometer.
Old Dec 1, 2011 | 05:51 PM
Car: 89 Formula 350
I'm just wondering if the settings I changed under tools in TP could have effected the chips I burt causing this issue??
Old Dec 1, 2011 | 05:55 PM
Engine: Lb9
Transmission: M20
I'm not sure on tunerpro, I think it has more code than tuner cats $6e is there a setting for magnetic or optical vss
Old Dec 1, 2011 | 05:59 PM
Car: 89 Formula 350
Yeah, I'm not sure. I think I really need to correct what I have checked off under...Tools> preferences> general> file Associations????
Right now the car speedo as well as the speedo in tuner pro will go higher as I rev the car even when I'm not moving in park.
Old Dec 1, 2011 | 09:25 PM
Car: 89 Formula 350
Maybe its not the bin and it could be a bad ecm or msd?
Old Dec 2, 2011 | 01:43 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
If the actual speedo is moving, higly unlikely to be related to tuner pro.
The next question to verify would be, Are you just datalogging with Tuner Pro or are you using an emulator with Tuner Pro?
Old Dec 2, 2011 | 04:26 AM
Car: 89 Formula 350
I use tp to datalog and make changes to burn chips. Is their a sensor that could be bad for speedo?
Old Dec 2, 2011 | 08:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
An '89 Firebird should have a 4-pole magnetic VSS in the transmission. Which then feeds to the 4-out buffer box under the dash (passenger side). The buffer box then feeds the ECM, speedometer, and cruise control. All on separate pulse streams.
The two wires from the VSS (yel & ppl) should be twisted together to alleviate noise issues. It also may be that one of them is open, or that one side of the VSS is open.
RBob.
Old Dec 2, 2011 | 11:57 AM
Since you're burning chips, and not using an emlator, then TP settings, caused by a laptop battery dieing can not cause this to happen.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
tmellott89
Oct 14, 2015 02:06 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
