Another EBL Tune Thread...
Old Dec 5, 2011 | 10:13 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Thought I'd make a thread in which I can post all of my EBL related questions and log my progress.
So far I have three learns done and I'm currently reading and learning to find out what to do and how I should take advantage of this
My engine is an almost completely stock (with the exception of the open element air cleaner) L03.
Up for review:
Thanks for looking!
Old Dec 6, 2011 | 10:17 AM
Ronny's Avatar
Re: Another EBL Tune Thread...
What are your VE Learns looking like?
Old Dec 6, 2011 | 11:58 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Here's latest VE learn (same as seen on VE low and high speed charts)
Attached Thumbnails Another EBL Tune Thread...-ve-learn-12-6
Old Dec 6, 2011 | 12:20 PM
Ronny's Avatar
now show the %%
Old Dec 6, 2011 | 01:15 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
You mean the corrections? Here are those: (from first learn to second learn)
Attached Thumbnails Another EBL Tune Thread...-ve-learn-percent-12
Old Dec 6, 2011 | 01:26 PM
Ronny's Avatar
It is adding a lot of fuel. eventually it will start to level out with some minus appearing. Change in temperature day to day will cause corrections as well.
Old Dec 6, 2011 | 01:56 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
That doesn't sound very good- especially since I clocked 16.5 mpg before that learn.
I entered 11psi for my fuel pressure because I'm not sure exactly what it is- could this be affecting it in a big way?
I was also running a code 23 (IAT low) because I disconnected the sensor and didn't get rid of the flag until now
Old Dec 6, 2011 | 01:59 PM
Ronny's Avatar
I woud add a FP gauge. summit brand that is not liquid filled.
No IAT? then change the IAT coolant blend to 100%
Old Dec 6, 2011 | 02:07 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Well not completely taken out, but moved to a cooler location than my air cleaner, but I'll do that.
Old Dec 6, 2011 | 03:31 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
And you mean 100% all the way down the chart?
Old Dec 6, 2011 | 10:30 PM
WilliamSilver's Avatar
IAT/CTS Blend filter is what your looking at right?
Think thats what he means.
Also,get a FP gauge, youll need to know what your FP is to really tune for fuel.
By the looks of that you might have a fueling issue. Take a look at my thread and youll see what i mean. My VE table was funky like that, had my injectors cleaned, did a few more learns and correct AE and it smoothed out great
Old Dec 7, 2011 | 09:01 AM
Ronny's Avatar
Yes all the way. all cells in table. If the IAT is not functional then we need to bias 100% to coolant. I would get the IAT repaired. It is helpfull when air temps vary day to day. In meantime you can uncheck the IAT flag so no CE light appears. Check EBL malf for any flags. I keep malf up on laptop while tuning.
Old Dec 7, 2011 | 10:14 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Actually, I can still plug the IAT into the air cleaner but I'm going to replace the stock air cleaner base pretty soon (I cut the sides off of my stock air cleaner but to remove the spacer ring I have to cut up the junkyard air cleaner top I bought). Yes, I do regret cutting up the OEM air cleaner now... should have just bought a whole unit at the junkyard and hacked that one.
But anyway, I'll plug the IAT sensor back in (I was following the Ultimate TBI guide) and I'll see if my friend can weld the sensor plug into the new base.
Now to change back all the CTS% values.
Old Dec 7, 2011 | 11:07 AM
VORTECCADDY's Avatar
Engine: 383 Superchared
Transmission: 700r4 built
Especially since we have been in the mid 50's this week, tonite will drop to low 30's
Old Dec 7, 2011 | 11:15 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Definitely. Baltimore weather is pretty fickle year-round. Btw, where in Baltimore are you located?
Old Dec 11, 2011 | 06:51 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Car's running much smoother now- no more "pulsing" at idle and it just runs better all around. The last VE learn with the IAT attached really did the trick. I'll try to send my Injectors out to fuelinjectorconnection.com next week for a clean and rebuild. I'm pretty sure that no one can beat $25 for cleaning/flow matching a pair of TBI injectors.
Now I've heard some talk about getting rid of the EGR function- what does EGR do, should I do this, and how is it done?
Old Dec 15, 2011 | 01:50 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
ttt- EGR
Old Dec 15, 2011 | 02:08 PM
Ronny's Avatar
http://autorepair.about.com/od/gloss..._egr-valve.htm
We removed the hardware(added headers so ext no longer supported) and turned off egr in the .bin(set enable temp to max)
Old Dec 15, 2011 | 03:28 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Exhaust Gas Recirculation.. well that sounds performance oriented (10). Just modded the .bin to get rid of it. Thanks
Old Dec 17, 2011 | 08:43 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Another question: what do you guys mean when you talk about "smoothing VE tables"?
Old Dec 19, 2011 | 09:32 AM
Ronny's Avatar
say you have a specific cell that is much larger or much smaller than the surrounding cells. It will modify that one as well as the surrounding to make it a smooth transition. See the graph function. Avoid peaks and valleys . Think of it as body putty?
Old Jul 11, 2012 | 04:21 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
https://www.thirdgen.org/forums/diy-...help-asap.html
Here's a link to the thread I created previously about the situation I had with, what I found out to be, my 30 degree advanced timing.
Now it's been running a lot better, but I plugged in to get some datalogs and logged a SA that looks like this over a 4.2 mile trip (city)
Also, my gas mileage seems to have gone down a bit since I fabricated my CAI. It draws air from a filter located where the cruise control module used to be. Then again, I don't have the IAT hooked up properly yet- going into the TBI hat. I know the TBI likes the intake air to be little hot, but I don't see why CAI would cause roughly a 2mpg drop.. especially in the summer when the air is already hot.
Attached Thumbnails Another EBL Tune Thread...-spark-knock-count-7   Another EBL Tune Thread...-spark-knock-average-retard
Old Jul 11, 2012 | 11:04 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Sorry to bump again, but are there any suggestions on what to do about the large amount of spark knock I'm getting? This car is my daily driver so I can't afford to mess it up.
Old Jul 12, 2012 | 07:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Pull some spark pugs out and check them for signs of detonation. See this link:
www.dynamicefi.com/SparkPlug.php
That will show you what to look for. If it is false knock it is killing your performance and mileage.
RBob.
Old Jul 12, 2012 | 09:29 AM
Ronny's Avatar
did you pull a significant of SA incrementally? You should see improvement as you pull SA.
I would pull 15% at a time until you see an improvement. If no improvement then odds are its mechanical.
I did just that and saw no improvement. My KC are at 2400 rpms 35 to 45 MAP and no wheres else. They appear out of nowhere one in 5 logs. During moderate accelleration like an xway ramp. My plugs looked normal cept cyl #2 had oil fouling last year. I am at 2 deg max retard during event. If fact I may just zero out the retard table. Not sure if it will still show in datalogs then?
Old Jul 12, 2012 | 10:03 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
@RBob. Pulled 4 spark plugs and none of them have peppering like the pictures you have. There's some discoloration, but I'll assume that's from normal engine wear after nearly 1000 miles, with a handfull of those miles being with bad timing and rich conditions. I'm going to try filling up with 93 octane to see what happens. I'll also look for sources of false knock-could be my exhaust for all I know- I haven't been tightening that like I should.
@Ronny- What exactly do you mean by pulling SA? Obviously, I haven't done this so please tell what you can
Edit: Took a second look, and I can see some peppering (yes, purple too) on the spark plug from cylinder number 2. This is most likely due to a hot spot I created when I scraped the heavy carbon deposits off the top of the cylinder with a screwdriver.. idiotic, I know now. However, this peppering is very light and barely noticeable. How should I go about dealing with this?
Old Jul 13, 2012 | 07:44 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
After work I took the valve covers off and checked the preload on the lifters. I tightened two up, but for all I know I could have 14 more loose lifters causing false knock. Since I have nothing better to do tonight, I'll try to re-check the load on all the lifters after I change the oil. 3/4 tank of 93 octane doesn't seem to have helped much either.
Oddly enough, looking through my old datalogs, even when the engine was stock (and in pretty bad running condition), it was recording a lot of knock.
Attached Thumbnails Another EBL Tune Thread...-spark-knock-count-713.jpg   Another EBL Tune Thread...-spark-retard-total-713.jpg
Old Jul 15, 2012 | 12:00 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Should I be using the L98 SA tables instead of the Vortec tables? The combustion chamber of the 059 Vortecs is D shaped, rather than heart-shaped
Rocket-Doc
Nov 14, 2015 02:08 PM
