VE range on 7747
Old Jan 28, 2012 | 08:51 AM
Mastiff's Avatar
VE range on 7747
What is the numerical range for the main VE table? Logically it seems like they shouldn't go over 100, but I'm getting very close to that as I tune. I'm wondering if I should scale the whole table down and adjust up BPW or VE adder table or something? Does the VE adder literally just add its number to the whole RPM row on the main VE?
Old Jan 28, 2012 | 01:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VE range on 7747
Range is 0 to 100%, with both tables added together. If the main table has the RPM as the rows the ECU/XDF is incorrect. See the Tuning Guide Book sticky, chapter 5, '8063/'7747/'8746 section for a thread on the VE tables.
RBob.
Old Jan 28, 2012 | 01:43 PM
Mastiff's Avatar
Here's a screenshot from TunerPro. RPM in rows. That's wrong? This is the factory ARJT and it adds to more than 100%. What's that mean?
Old Jan 28, 2012 | 10:48 PM
EagleMark's Avatar
RBob.
Just read those articles and none inperticular to $42. But $61 was noted it was RPM column and MAP rows, the XCU/XDF was wrong.
https://www.thirdgen.org/forums/diy-...yyyy-down.html
I have been wondering why VE Main and Adder add up to over 100? Over tha last 5 years I have found 4-5 XDF for $42 and combined them all, they were all the same as Mastiff pictured? Has this been wrong forever?
Old Jan 28, 2012 | 11:02 PM
EagleMark's Avatar
From the ASDX $42 hac
Code:
        ; MAIN FUEL (VE1) Vs. MAP Vs. RPM
        ; 10-05-2000 Dissassemby of ASDX
        ; 8 COL x 9 BLOCKS =  72 BYTES
        ;  TBL =  2.56  * VE %
        ORG $037C   ;
L037C   FCB	 0      ; MIN RPM Val
L037D   FCB	 16     ; Min KPA MAP Val
L037E   FCB	 8      ; LINES/BLOCK
        ; 20 KPA MAP
        ;                  VE %            RPM
L037F   FCB  5      ;       2.0             400
L0380   FCB  10     ;       3.9             800
L0381   FCB  15     ;       5.9            1200
L0382   FCB  25     ;       9.8            1600
L0383   FCB  36     ;      14.1            2000
L0384   FCB  46     ;      18.0            2400
L0385   FCB  66     ;      25.8            2800
L0386   FCB  75     ;      29.3            3200
        ; 30 KPA MAP
        ;                  VE %            RPM
L0387   FCB  36     ;      14.1             400
L0388   FCB  63     ;      24.6             800
L0389   FCB  79     ;      30.9            1200
L038A   FCB  96     ;      37.5            1600
L038B   FCB  107    ;      41.8            2000
L038C   FCB  109    ;      42.6            2400
L038D   FCB  106    ;      41.4            2800
L038E   FCB  90     ;      35.2            3200
        ; 40 KPA MAP
        ;                  VE %            RPM
L038F   FCB  36     ;      14.1             400
L0390   FCB  64     ;      25.0             800
L0391   FCB  90     ;      35.2            1200
L0392   FCB  103    ;      40.2            1600
L0393   FCB  112    ;      43.8            2000
L0394   FCB  114    ;      44.5            2400
L0395   FCB  118    ;      46.1            2800
L0396   FCB  116    ;      45.3            3200
        ; 50 KPA MAP
        ;                  VE %            RPM
L0397   FCB  45     ;      17.6             400
L0398   FCB  65     ;      25.4             800
L0399   FCB  97     ;      37.9            1200
L039A   FCB  109    ;      42.6            1600
L039B   FCB  117    ;      45.7            2000
L039C   FCB  122    ;      47.7            2400
L039D   FCB  125    ;      48.8            2800
L039E   FCB  127    ;      49.6            3200
        ; 60 KPA MAP
        ;                  VE %            RPM
L039F   FCB  79     ;      30.9             400
L03A0   FCB  92     ;      35.9             800
L03A1   FCB  105    ;      41.0            1200
L03A2   FCB  116    ;      45.3            1600
L03A3   FCB  124    ;      48.4            2000
L03A4   FCB  127    ;      49.6            2400
L03A5   FCB  135    ;      52.7            2800
L03A6   FCB  137    ;      53.5            3200
        ; 70 KPA MAP
        ;                  VE %            RPM
L03A7   FCB  97     ;      37.9             400
L03A8   FCB  100    ;      39.1             800
L03A9   FCB  108    ;      42.2            1200
L03AA   FCB  120    ;      46.9            1600
L03AB   FCB  126    ;      49.2            2000
L03AC   FCB  136    ;      53.1            2400
L03AD   FCB  140    ;      54.7            2800
L03AE   FCB  137    ;      53.5            3200
        ; 80 KPA MAP
        ;                  VE %            RPM
L03AF   FCB  103    ;      40.2             400
L03B0   FCB  106    ;      41.4             800
L03B1   FCB  113    ;      44.1            1200
L03B2   FCB  123    ;      48.0            1600
L03B3   FCB  131    ;      51.2            2000
L03B4   FCB  135    ;      52.7            2400
L03B5   FCB  140    ;      54.7            2800
L03B6   FCB  141    ;      55.1            3200
        ; 90 KPA MAP
        ;                  VE %            RPM
L03B7   FCB  110    ;      43.0             400
L03B8   FCB  115    ;      44.9             800
L03B9   FCB  122    ;      47.7            1200
L03BA   FCB  125    ;      48.8            1600
L03BB   FCB  133    ;      52.0            2000
L03BC   FCB  143    ;      55.9            2400
L03BD   FCB  144    ;      56.3            2800
L03BE   FCB  152    ;      59.4            3200
        ; 100 KPA MAP
        ;                  VE %            RPM
L03BF   FCB  120    ;      46.9             400
L03C0   FCB  120    ;      46.9             800
L03C1   FCB  124    ;      48.4            1200
L03C2   FCB  127    ;      49.6            1600
L03C3   FCB  128    ;      50.0            2000
L03C4   FCB  148    ;      57.8            2400
L03C5   FCB  159    ;      62.1            2800
L03C6   FCB  160    ;      62.5            3200
And the adder:
Code:
   ; MAIN FUEL TBL vs RPM, FL2
        ; 01-31-2000 Dissassemby of asdx
        ;  17  BYTES
        ;  TBL =  2.56  * VE %
        ORG $03C7   ;      VE %            RPM
L03C7   FCB  64     ;      25.0            0
L03C8   FCB  100    ;      39.1          400
L03C9   FCB  100    ;      39.1          800
L03CA   FCB  100    ;      39.1         1200
L03CB   FCB  100    ;      39.1         1600
L03CC   FCB  100    ;      39.1         2000
L03CD   FCB  100    ;      39.1         2400
L03CE   FCB  100    ;      39.1         2800
L03CF   FCB  100    ;      39.1         3200
L03D0   FCB  105    ;      41.0         3600
L03D1   FCB  90     ;      35.2         4000
L03D2   FCB  82     ;      32.0         4400
L03D3   FCB  55     ;      21.5         4800
L03D4   FCB  45     ;      17.6         5200
L03D5   FCB  25     ;       9.8         5600
L03D6   FCB  0      ;       0.0         6000
L03D7   FCB  0      ;       0.0         6400
Old Jan 28, 2012 | 11:10 PM
EagleMark's Avatar
This has been a topic I bring up a lot when tuning $42 1227747 ECM that the totals come up over 100?
Just looked in TunerCat software and it is the same as the TunerPro XDF?
Old Jan 29, 2012 | 12:44 AM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
i remember reading one of RBob's tuning articles and, for whatever reason, the main VE table + adder equaled more than 100. it has something to do with the calc's maybe? in my situation i just keeping adding and when the PW doesnt increase anymore i know ive reached the PW limit lol.
Old Jan 29, 2012 | 08:17 AM
Mastiff's Avatar
How can you tell the PW isn't increasing?
Also, I've been following the advice of pulling the VE2 table into VE1 for easier tuning. In that case on ARJT some cells are already over 100 and tunerpro truncates them to 100 right in the table.
Old Jan 29, 2012 | 08:19 AM
EagleMark's Avatar
I've tuned many 7747 as is. Some guys say to add adder table to main VE and work off it. That is when I found a stock chip is already over 100. So I left it be and just tuned main VE. Once I get to 95 I raise fuel pressure and start over... now I use an Injector Calculater which uses injector size engine approx HP and calculated fuel pressure. This way I know I have enough fuel top end, then tune...
Old Jan 29, 2012 | 08:23 AM
Mastiff's Avatar
Is fuel pressure adjustable on a factory TBI setup? I thought it was just built in.
Old Jan 29, 2012 | 08:29 AM
EagleMark's Avatar
It is built in and should be 13 psi. You can make or buy an adjustable FPR. But with your other bubbles in fuel filter I think your sucking air to get your 10 PSI.
Old Jan 29, 2012 | 09:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The reason they are wrong is because some number of years ago (16?) I got it wrong when I updated the existing (Jay's, IIRC) '7747 ECU file. I corrected it shortly afterward but it fell on deaf ears. It is the one table of many that GM swapped the axis on, so maybe folks didn't believe me when I sent out the correction.
Since then it has been a never ending battle, even many of the '8746 ECU files are the same way, maybe copied my '7747 ECU updates? If it is missing a MAP row, then they were copied, as I also goofed that up.
As for the VE1 and VE2 adding up to more then 100%, yup, even the GM tuners got caught on that one. The ECM will note this and set it to 100% to prevent overflow to a lower number.
The two VE tables are a PITA, which is the first thing I was rid of when I started to re-write the ECM firmware (also went to larger and higher resolution tables).
RBob.
Old Jan 29, 2012 | 10:32 AM
EagleMark's Avatar
Well it's not falling on deaf ears here!
So the Rows should be MAP and Columns RPM?
But VE adder is correct?
Old Jan 29, 2012 | 12:52 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes & yes.
RBob.
Old Jan 29, 2012 | 01:33 PM
Mastiff's Avatar
Hold on, is the thing I posted actually wrong, or just rotated? I can't see how it could be mislabeled since there are 7 rows and 9 columns. Why does it matter if it's transposed?
Old Jan 29, 2012 | 02:09 PM
EagleMark's Avatar
8 and 9...
Old Jan 29, 2012 | 02:36 PM
Mastiff's Avatar
8 and 9...
Same point/question. The labels can't be wrong, so what difference does it make which axis is X or Y?
Old Jan 29, 2012 | 03:08 PM
EagleMark's Avatar
Yes & yes.
RBob.
I don't know Bob? I just copied the VE Main and set it up RPM columns and MAP rows and it does not read the bin file correctly? Unless something else is wrong? The origanal way is reading from the $42 HAC of ASDX correctly but not if I switch rows and columns?
Old Jan 30, 2012 | 07:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
From the '7747 hac. Here is the SA table look up:
Code:
	LDX	#$D032		; MAIN SA TABLE
	LDAB	L0026		; S/D MAP
	LDAA	L001B		; rpm / 12.5 & 25, brk @ 2400, start 400 rpm, limited to 3600
	JSR	LFB67		; 3d LK UP
MAP in reg B and RPM in reg A, for rows as RPM.
Then the VE1 look up:
Code:
	LDAA	L0026		; S/D MAP
	LSRA			; DIV BY 2 FOR LK UP
	LDAB	L001C		; RPM/25
	CMPB	#128		; 3200 RPM
	BLS	LD6BD		; BR IF RPM LT 3200
	LDAB	#128		; FORCE 3200 RPM
LD6BD:	LDX	#$D37C		; POINT TO FL 1 TABLE
	JSR	LFB67		; 3D LOOK UP
In this case the MAP is loaded into reg A, and the RPM is in reg B. Which makes the rows MAP.
RBob.
Old Jan 30, 2012 | 02:22 PM
EagleMark's Avatar
RBob, you know I take your word as a mentor! And well that explains it, but why does it not work?
I ran a log file and data tracing with both VE Main and VE Main Corrected, changed row and column axis and the corrected one stayed at 100 MAP 400 RPM while the original worked fine...
So is just changing the table to correct not enough. It reads the bin wrong and data traces wrong. While the one that is built wrong (original) works right?
EDIT: Since they got VE Main and VE Adder over 100 as a mistake could this be a mistake too?
EDIT: Removed wrong xdf, correct XDF is below.
Old Jan 30, 2012 | 05:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Figured it out, the XDF entry for the VE1 table is column centric, not row centric which is the default. Which makes the entry correct, but can't tell without looking at the XDF file.
Change the new 'VE as % (FL1) Corrected' entry to row centric and it is correct.
Not sure why that entry parameter would be used, as it adds another level of complexity and confusion. See the Major Order parameter in the pic.
RBob.
Old Jan 30, 2012 | 05:47 PM
EagleMark's Avatar
Well that did it!
VE from HAC are in place, data tracing is working correctly!
But since you compared it to spark above I looked at my Main Spark advance and it is set to row? But data tracing seems to work fine either way if I set columns or rows? Sure changes where the spark numbers are though? Main Spark has always been MAP kpa acorss top and RPM down left side, like new corrected Main VE table... but set to row?
Old Jan 30, 2012 | 06:19 PM
Mastiff's Avatar
Okay, for those of us who don't live and breathe this stuff, is something actually wrong in TunerPro that needs to be fixed?
Old Jan 30, 2012 | 06:37 PM
EagleMark's Avatar
You don't live an breathe this stuff?
JK...
The Main VE is fixed thanks to RBob, I checked the spark table and it lines up with $42 HAC. I was just asking if it needed a corection as well.
File Type: zip
Old Jan 30, 2012 | 07:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The XDF/Tuner-Pro is OK as you have it shown originally.
Can also do it the latest way EagleMark did, by going back to the default settings and changing the row/column annunciation. Which will show the rows & columns swapped.
My preference would be to use the method that follows how GM did the table layout. Which is using the row centric layout and with the MAP as rows and RPM as columns.
Note that this is for the VE1 table, no others.
RBob.
Old Feb 5, 2012 | 09:44 AM
ervin's Avatar
HI RBOB.JUST A QUESTION .IF 747 VE TABLE GOES 6400 RPMS,WHY IS 730 SO POPULAR?OR IS IT JUST A BAUD THING.ARE THERE OTHER ECMS THAT GO HIGHER AND COMPAT. WITH 91 STYLE IGNITION & FUEL SYSTEMS?
Old Feb 5, 2012 | 09:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '7747 ECM in stock form runs a 2-bbl TBI set up. It is also a truck ECM that doesn't support an IAT.
The '7730 ECM in stock form is for MPFI set ups (like TPI), or a single 1-bbl TBI (on 4-bangers).
The '7730 is stock in '90-'92 f-body TPI set ups and the 3.1l MPFI set ups.
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
tmellott89
Oct 14, 2015 02:06 PM
JSDaddy189
Sep 26, 2015 03:50 PM
