Super AUJP timing too aggressive?
Old Feb 13, 2012 | 09:23 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, i have a SAUJP v3 ccp bin, but the timing tables look a little aggressive for an F-body 350 TPI. It is like 10 degrees higher in some spots. That sounds more suited for an aluminum headed Vette. What do you guys recommend as far as changing the numbers in the Spark Adv. main table in Tunerpro? I want it a little more aggresive than my current stock AUJP bin,but i am unsure of how far i can go? and if i do succeed in getting the timing table the way i like then what else do i have to change next to match it? VE tables? and i dont want to hear "check out the stickies on tuning". Thanks
Old Feb 13, 2012 | 09:34 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Super AUJP timing too aggressive?
Can i just copy and paste my stock timing tables into the SAUJP? What other changes would i need to do after this? Someone on here has to know the answer
Old Feb 13, 2012 | 09:42 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Yup go ahead copy your stock timing tables if you do not have aluminum heads. Other than that your good to go.
Old Feb 13, 2012 | 09:59 PM
ninetyone's Avatar
Axle/Gears: 3:42
So you are sure? I thought i would have to adjust the fueling too? idk. I mean i can adjust the VEtables below 3krpms with VEMaster.
Old Feb 14, 2012 | 01:10 AM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
copying the appropriate timing tables for your engine will be just the first step. So you are "good to go" to start tuning. After the first few times you adjust the VE tables you'll probably be most of the way there, you'll be drivable. For the most part the rest is all "fine tuning" that can be done at your own pace while still using the car for transportation if need be.
Old Feb 14, 2012 | 02:11 PM
utilityguy2's Avatar
Curious as to why you are using a old version of SAUJP?
S_AUJP_V41026 is much better in my opinion.
Old Feb 14, 2012 | 02:16 PM
ninetyone's Avatar
Axle/Gears: 3:42
Well long story. I ditched my Hypertech for a stock AUJP. That is what the guy who burned my chip made me. Now that i know a little about tuning,i am ready to buy a prom burmer and experiment.
Old Feb 14, 2012 | 03:28 PM
Sounds like you are using a G1 adapter with a programable EEPROM. What are you using for a Memcal if I may ask?
Old Feb 14, 2012 | 03:49 PM
ninetyone's Avatar
Axle/Gears: 3:42
the one u made me.lol
Old Feb 14, 2012 | 04:53 PM
LOL that's what I thought.
Azrael91966669
25
Jun 20, 2017 04:04 AM
BADNBLK
Nov 16, 2016 09:12 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
89fast5oh
Sep 27, 2015 09:04 PM
beachrodder
Aug 7, 2015 04:27 PM
