Tunerpro?
Old Mar 26, 2012 | 12:20 PM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
Tunerpro?
i downloaded tunerpro today (its free so why not). but what do i do with it now haha? how do i connect it to the car? Im just looking to do some data logging for the fun of it.
Old Mar 26, 2012 | 01:36 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Tunerpro?
assuming you downloaded V5, find the correct ADX for your application, download it, select it in tunerpro via the "acqusition" menu, connect to the ECM, record, drive, stop recording, save the file.
that's the logging portion explained.
Old Mar 26, 2012 | 05:04 PM
Engine: 305 LO3
Re: Tunerpro?
How do you connect to the ECM
Old Mar 26, 2012 | 05:16 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Tunerpro?
assuming the ADX is setup correctly, either press Ctrl + F4 or go to Acquisisiton->start/stop data scan.
Old Mar 26, 2012 | 05:23 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Tunerpro?
All the info. is on the website. You need to buy the hardware to connect the aldl socket to your computer. And you could shoot the guy some cash for the software too. he deserves it!
Old Mar 26, 2012 | 08:47 PM
gp90gta's Avatar
Car: 1990 GTA
Re: Tunerpro?
What are you looking to do, just some dataloging? if so you will need hardware to hook up to the ALDL for that, If your looking to start tuning then you have options. Do some searching here and if you have questions just ask before you buy anything.
Old Mar 26, 2012 | 10:40 PM
Engine: 305 LO3
Re: Tunerpro?
right now all i want to do is some data logging i also downloaded winaldl, maybe down the road tuning but not anytime soon
Old Mar 26, 2012 | 10:51 PM
Engine: 305 LO3
Re: Tunerpro?
im confused on which aldl cqable to buy im guessing this one? http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
Old Mar 26, 2012 | 11:00 PM
gp90gta's Avatar
Car: 1990 GTA
Re: Tunerpro?
I dont know about that cable but I'm sure someone will chime in on it, I was using the aup1 from Moates.net to do my datalogs and burn chips but since then I picked up aldu1, also from Moates, works great but more expensive then the one you posted.
Old Mar 26, 2012 | 11:05 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Tunerpro?
i had the aldlcable version for a while. worked, most of the time, for about 12 months of ~once a week usage, then it became flaky to the point of failure within about a week. i tore it apart and used the nice molded male connector to make my own cable. had that running for almost 2 1/2 years now with no issues.
Old Mar 26, 2012 | 11:06 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Tunerpro?
I use the Moates' version, works great, EVERY time.
Old Mar 27, 2012 | 05:18 AM
EagleMark's Avatar
Re: Tunerpro?
That would be the correct cable. But my first one did not work, second one did...
I agree to support Moates as they support us with all the other cool stuff your going to need down the road. I have their AutoProm that is a cable, emulater and chip burner in one unit and has worked flawlessly for years!
Once you get to using TunerPro pay the $30 registration fee so he keeps making us cool stuff!
I did a tunerPro tutorial startup and have a TunerPro XDF and ADX lookup done in excel spreadsheet along with many writeups on how to use some of the features of TunerPro. The more you use it the more you find how wide open it is to customizing everything you want to do.
http://www.gearhead-efi.com/Fuel-Inj...ro-Tuning-Talk
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
