Flash EPROM through ALDL
#51
Car: 87 Z28 IROC T/Top Right Hand Drive
Engine: 305 TPI, 081 Heads, heavily modded.
Axle/Gears: 2.73:1 (should be 3.0+)
Re: Flash EPROM through ALDL
Okay. If I use the values from the ABUT which has a Spark Reference Angle of 6* should the BLCF Spark Reference Angle be changed to match it at 6* as well, or will it be okay so long as it matches the physical setting at the crankshaft?
Currently SRA is 9.84* in the binary and at the crankshaft (mark on the balancer).
The stock SRA (in ABUT) is 6*, but I understand it will be okay at 10*?
#52
Car: check
Engine: check
Transmission: check
The spark reference angle (initial SA) needs to match where the distributor is set. Stock for TPI being 6* BTDC.
RBob.
RBob.
#53
I've arranged to take the car to a dyno tuner for an assessment in the next few days. I am wondering whether I should set it at 6* BTDC or at 10* BTDC.
The engine has 11:1 compression, so I tried putting 1 litre of E85 Ethanol into 1/4 tank of fuel - it seems to make a bit of a difference but hard to tell if it's that or something else since the tune changes so much at the moment.
I wonder whether it might be good to swap in a slightly thicker head gasket to reduce the compression to an acceptable 'pump gas level'?
#55
Cool :-) the cam is Comp Cams 08-502-8 Grind#XR269HR, will that do it?
Now that I have $12P running I want to also put $8D Super_AUJP onto the NVRAM. The Aussie board has a jumper to hard switch to extend the address space in the module - like having two EPROMS I suppose.
I've got the code into TP5 and set it up roughly to start, but I'm not sure how to go about burning it into the NVRAM through the USB cable. Maybe it needs to come out and flash it in a programmer?
I'm familiar with that process, but not too sure what address offset to write the 32K $8D bin, is it 0x8000.
Last edited by Sandgroper; 08-29-2012 at 12:36 PM. Reason: clarify question & update
#56
would be curious to hear your 730 results. Thats one heck of a deal for the au nvram.
http://delcohacking.net/forums/viewtopic.php?f=7&t=655
I'm hoping to get Super_AUJP ($8D) code running on it in conjunction with OSE $12P. The wire on the bottom right of the pic splits the address space into 2x64K spaces (0x0-0xffff & 0x10000-0x1ffff).
Last edited by Sandgroper; 08-30-2012 at 06:49 AM. Reason: more info on addressing
#58
The knock sensor hasn't been working properly... While looking for ways to run $8D code on my '808 (aka 1227165) I stumbled across this note about '165 external ESC Knock Sensor Module 100 K ohm signal.
It may require a 3.9K ohm resistor to bias the 100 K ohm signal so I'm going to try and jumper pins A12, and B11 (was B7 before $12P) with a resistor.
[Edit] I tried this and it works - I'm stoked man!
I was getting constant knock at around the 200 count mark, and of course constant spark retard with that. Not anymore... woo hoo!
#59
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
#60
It just crossed my mind, that I am still running the external ESC Knock Sensor module with a 4K ohm resistor across pins A12 and B11 to bias the 100K ohm signal.
Maybe that has something to do with it?
It did start at some point but stops after a couple of seconds pass. Similarly if you touch the throttle it will stop. Hmmm?
Last edited by Sandgroper; 08-31-2012 at 06:00 AM. Reason: more wiring info B7 to B11
#61
#62
Take a look at this http://www.exatorq.com/ludis_obd1/p4xref.html
I suggest that you get it tuned first then work on the other fun projects as I have found that they can get you side tracked. Make sure that your distributor setting maches whats in tunnerpro so things read right.
#63
Does this also apply to AUJP and Super_AUJP, those tables show advance cells greater than 42*, where does the -3.5* - 42* limitation come from?
#64
#66
1 Post
Engine: 3xx ci tubo
Yes... I am running the OSE $12P software and a Speed Density MAP setup instead of MAF. So the pins have been wired to suit that. It's similar wiring as the 1227165 to 1227730 conversion except B7 moves to B11. I have a (temporary?) jumper wire from B11 back to B7.
No, $12P and 730 ECM is a no go even if you re-pin the ECM connector. Look at the Microprocessor schematic and you will see MUXC and others need control on the 730 ECM that the $12P code does not do. Again, you need code changes to the $12P to run on a 730 ECM.
#67
Cool. Straight to the point... I appreciate that junkcltr, thank you. I'll look into that when I get some more time. Just got distracted again at the moment...
#68
#69
Check out this thread on delcohacking http://delcohacking.net/forums/viewtopic.php?f=9&t=2543 it's made of the same stuff...
#70
If that's a mechanical limitation... Then I think it might be possible to shift it by changing the Spark Reference Angle. Only if necessary to get more advance. E.g set SRA to 10' (from 6) would that then give a range of between -0.5' and 46'?
#71
Car: check
Engine: check
Transmission: check
RBob.
#72
Assuming (below) that the Spark Ref Angle (SRA) always matches between the calibration and at the crank...
When the SRA is set to stock at 6* - I understand the Max Retard is -3.5* and Max Advance is 42*.
So when SRA moves +4* i.e. to an SRA of 10* would that not shift the range by 4*?
I don't get how you've derived a range of 6.5* to 52* - or am I misunderstanding - not too sure. What did I miss?
#73
Car: check
Engine: check
Transmission: check
Same for the maximum retard allowed in the distributor.
RBob.
#74
Recall that it is the limits of the distributor, not the calibration. Being able to program a maximum of 42* advance into the distributor, the base setting gets added to that. Which is 48* BTDC at the crankshaft with an initial of 6*.
RBob.
RBob.
The distributor range limits are added to the base, which is the SRA. I understand that part...
I would be grateful if you could look at the attached XDF ($12P) and advise which are the relevant settings.
http://delcohacking.net/forums/downl...le.php?id=4323
This is a link to a recent bin if it it helps too.
http://delcohacking.net/forums/downl...le.php?id=4321
#75
I've been scanning through the $12P thread, but haven't found the question asked or answered yet, can $12P be used without an NVSRAM (or similar) product?
I would think that it could be used with an Ostrich, or EPROMs, but completely sure.
I hadn't previously considered using $12P, since it was only speculated that it would work in the '7165.
--==EDIT==--
A few pages later, and it seems that it should work with an Ostrich, since it works with EPROMs, just lacks the ability to auto tune the VE table, which is fine with me.
--==EDIT==--
#76
Car: check
Engine: check
Transmission: check
EST params - Maximum Spark Advance from TDC
EST params - Maximum Spark Retard from TDC
It is really from the SRA, not TDC.
Note that in the Tuning Guide Book sticky, chapter 5, the 8063/7747/8746 ECM section there is a write up on the SA logic.
RBob.
#77
So if the SRA if 10* BTDC, and the distributor has a movement range of 45.5* then I would initially guess that these variables ought to have the following values...
EST params - Maximum Spark Advance from TDC = 42*
EST params - Maximum Spark Retard from TDC = -3.5*
and, the above values are still correct if it's from the SRA instead of TDC as you say.
Would it be correct to think of it as the SRA is at zero on the distributor?
So that being the case SRA at 10* crank, and zero on dizzy would give an effective timing range between 6.5* and 52* - is that right?
I searched these forums and Google for the Tuning Guide Book sticky, chapter 5, the 8063/7747/8746 ECM section to see the write up on the SA logic.
All I found was other references to it but no links to it. I would like to read it, have you got a link to it?
#79
Car: check
Engine: check
Transmission: check
Your other questions have already been answered. Go through this thread again and re-read the stuff.
RBob.
#81
Digging up an old thread, but ive joined 3rd gen for a visit from delcohacking land and have been having a look around. I just wanted to clarify here - it sounds like your other codes are differnt - but in 12P the spark reference angle refers to the timing input to the ECU. That is when the ecu gets the electrical signal from the reluctor, so 10 degrees BTDC means that the ecu is triggered when the engine is at 10 degrees BTDC. That part of the system is isolated from the rest and should be configured to match your trigger hardware. The 10 comes from the default setting used by GM in most of their reluctor ignition modules. They fire when they see the trigger (no delay) when they are cranking, so the 10 degrees BTDC offset gives you a 10 degree BTDC spark when cranking before the ecu has synced up and takes over. The GM spec is 10 degrees and should match your distributor.
Everything else spark related shows real world spark timings - you do not need to take your reference angle in to account. Thats the main spark tables, limit tables, the displayed timings, they should all match exactly what you see on your timing light regardless of the reference angle of your trigger system.
Also, beware converting MAF load tables to MAP. Your engine might run, but they are different relationships. The MAP VE table shows how well your engine is breathing based on pressure not airflow. Typical VE tables drop back down again at higher RPM and past the point of max torque, and when the ecu calculates the air and then fuel, the rpm makes up for more than the amount the VE is decreasing. Thus the result is still more fuel overall. In a MAF table your measuring airflow so the tables wont back down, they will be lowest at lowest load and highest at highest load. So it is not a 1:1 relationship to the MAP tables with different scaling.
Probably a better approach would be to get one of the default commodore tunes for an engine with the same number of cylinders, adjust the injector rate if needed, then adjust the whole VE table by the % difference in engine capacity. This way, even though the VE wont be perfect, it'll at least have the right kind of shape. Hope that clears things up!
#82
bump
