Memcal ESC repair
Car: 87 Callaway/90 Zr-1/92 ZR-1
Engine: TT TPI/LT-5
Transmission: 4+3/ZF-6
Axle/Gears: 2.73/3.45/4:09
Memcal ESC repair
Came to the experts with a question....my Memcal for my 92 took a dump, specifically the ESC board is cracked.....can these be repaired. Finding an LT-5 chip for a 92 is not easy....need help!!!
Thanks!
LGAFF
92 ZR-1
90ZR-1
87 Callaway TT
Thanks!
LGAFF
92 ZR-1
90ZR-1
87 Callaway TT
Transmission: 5-speed/T-5
Re: Memcal ESC repair
If the crack is only across the board traces, then with some patience, and good soldering equipment it could likely be repaired. If there are broken components, then the repair would be more difficult, because of the need to source the components.
How did it get cracked?
Engine: TT TPI/LT-5
It happened, I believe, when I was trying to put in a moates with the chip....I just spoke with Byron Johnson at GMEPROM.com.....he can either send me a replacement prom for $140 or put an LT-1 Knock module in my existing chip...ayone dealt with them before?
Engine: TT TPI/LT-5
I would be interested to see what the LT-1 knock sensor would do as a replacement. Would I tend to see more false knock counts?, etc....sorry not a tuner so not familiar with how it all works
Car: check
Engine: check
Transmission: check
For a filter, can swap one from another MEMCAL onto yours. Ones that are a very close match, the LB9, '90-'92 TPI 5.0L f-body knock filter is a good choice.
Another good choice is the LH0, '90-'92 MPFI 3.1L f-body knock filter.
They can be swapped onto your MEMCAL. Need to be careful, but it is doable.
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I wouldn't recommend an LT1 knock filter, the center frequency doesn't match up. There are better options available. First need to decide whether you want to keep the stock CALPAK's. For an LT5 engine it would likely be best to.
RBob.
RBob.
Good to know there may be some subs available. As usual, thanks.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
RBob.
RBob.
If these knock filters would work, couldn't we avoid the soldering issue just by using that memcal w a Moates adapter for the LT-5 specific calibration piggybacked? Or is the form factor different?
Car: check
Engine: check
Transmission: check
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
sorry about the off topic just wanted to share with the lt5 guys.
Engine: TT TPI/LT-5
That is being developed by a ZR1 registry member...good post.
