Unable to copy ign timing table
Old Jul 3, 2012 | 09:53 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I'm in the process of switching bins using TunerProRT.
I can copy and save everything except the ign timing table.
I can copy the table, save the table, save the file, but when I re-open it, all the ign table values are back to prev.
Anyone else seen this before?
Old Jul 4, 2012 | 06:13 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: Unable to copy ign timing table
Can you change each/any entry in the table manually by overwriting?
Old Jul 4, 2012 | 06:20 AM
EagleMark's Avatar
When you copy a complete table to complete table they have to be identical. Not one from stock bin and one from extended table hacked bin etc....
That said when you do copy the new table in any numbers differant will be in red, then need to click the Commit Icon/Button to make changes then save bin before exiting.
Are you using Compare to see and copy new tables?
Old Jul 4, 2012 | 11:44 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Both bins have been hac'ed to allow WB02 to be included in datastream. Other than that, they are normal bins.
If I highlight all the cells and hit "copy from compare", all values turn red even the ones that are same number.
I am hitting commit then saving bin.
Tried "copy from compare" with only one row or column, no help.
Tried direct entry, no help.
I've also tried just changing one cell using the "fill with value" option, no help.
Old Jul 5, 2012 | 11:33 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Could be something with the XDF that the calculation value is incorrect causing nothing to update due to the error.
Check the conversion tab and see if the calculation is correct.
Old Jul 5, 2012 | 01:59 PM
utilityguy2's Avatar
Don't know if you found solution but I had similar problem. Turns out that in the spark chart I was trying to copy, one number was higher than the max set in code so none would copy. here is link to that post. https://www.thirdgen.org/forums/diy-...-tunerpro.html
Old Jul 6, 2012 | 10:24 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I checked the xdf's conversion tab for the spark table.
It has " 0.351567 * X + 0.000000 " in the top left cell (and at the top of the screen). All the other cells are blank.
Is that correct?
None of the spark table values are higher than what a stock ARAP bin has.
Old Jul 7, 2012 | 08:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In the XDF editor dialog, General tab, see if the Use Low Range and/or Use High Range is selected. Then check what the low & high values are set too. This was causing another user the same issue.
The Use High Range value was lower then one or more of the values in the table being copied from.
RBob.
Old Jul 7, 2012 | 12:06 PM
RBob.
Thanks RBob for helping me with that one. I was pulling my hair out on that one. And it's probably ZZ's answer also.
Old Jul 8, 2012 | 11:08 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
You nailed it RBob!!
Old Jul 8, 2012 | 11:22 PM
EagleMark's Avatar
So what XDF is causing the issue?
Old Jul 9, 2012 | 05:00 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
The one I downloaded from here:
http://www.tunerpro.net/downloadBinDefs.htm
The first one on the list.
Issue was resolved thx to RBob.
High value was set too low (43 degs).
I have a max value of 47 degs in my spark table (ARAP).
Old Jul 9, 2012 | 05:52 PM
EagleMark's Avatar
I'll be... mine too! Thought I knew TP fairly well and never used this feature. Pretty sweet seeing colors in table when they are set...
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
