chip addressing vs. buffer addressing
Old Apr 21, 2013 | 10:51 AM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
would someone please explain chip addressing vs. buffer addressing when using Flash & Burn? and then how/why it's different for the different chips? I understand the chips are of different size, but don't they all start in the same place? (at the beginning?) and then what if you read the information off of a AT27C256, modify the bin and then want to burn it to a 27SF512 what would the settings be in Flash & Burn? I'm having trouble drawing a mental picture of how all this stuff fits together....
Old Apr 21, 2013 | 11:10 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: chip addressing vs. buffer addressing
The eprom adress is where you are reading the eprom. The Buffer address is where the EPROM image in a memory buffer. Offset is where you are programing a smaller size of data to a larger eprom.
Old Apr 21, 2013 | 11:51 AM
greggbruce's Avatar
um, yeah, already understand that....but doesn't answer my questions.
Old Apr 22, 2013 | 11:52 AM
EagleMark's Avatar
Bin files are differant sizes but can all be used on same chip which is larger then all of them. Offset puts bin on end where it can be used.
Look at this page and the 27FS512 offsets, notice the all differant size bins all end up at 00FFFF ?
http://support.moates.net/programmin...using-offsets/
Reading stock chips is different as well, no offset for buffer.
http://www.gearhead-efi.com/Fuel-Inj...Flash-and-Burn
Old Apr 22, 2013 | 10:59 PM
greggbruce's Avatar
HEY --- THAT helps -- that's some of what I was looking for, all the files should line up at the END ---- thanks a bunch !!!
Linson
Oct 24, 2025 02:00 PM
$750 L98
Feb 1, 2025 02:25 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
InfernalVortex
Apr 20, 2021 11:31 AM
jaridjohn
Oct 5, 2015 07:01 AM
