Decel enleanment 6E..HELP!
Old May 12, 2013 | 12:34 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I'm getting a rich AFR spike just after a WOT pull. My datalogs/WB show it going from my mid/high 12s at WOT to mid 11's when I lift off the throttle. Can someone point me to the correct place in TP5 to correct this. Also do I increase of decrease the value to to lean out the DE..Thanks
Old May 12, 2013 | 07:42 PM
Car: 89 Formula 350
Re: Decel enleanment 6E..HELP!
maybe a quick rich spike is normal just off wot??
Old May 13, 2013 | 10:42 AM
Ronny's Avatar
Do you have in your mask DFCO?
Old May 13, 2013 | 06:43 PM
Car: 89 Formula 350
Yes Ronny,I have a lot of DFCOs
DFCO enable if RPM above...set to 1200 rpms
DFCO remain if RPM above...set to 900 rpms
DFCO disable if temp less then....set to -40
DFCO enable if conditions met foe x ...set to 1 second
DFCO enable if LV8<x ...set to 30.00
DFCO remain if LV8 <x... set to 40.00
DFCO Max RPM decrease/12.ms..set to 87.5 RPMs
DFCO enable if % TPS <x ..set to 3.13
DFCO disable low vss speed limit..set to 15mph
DFCO consecutive minimum delay..set to 6.39 seconds
just not sure which one to change, and which way to go with the value.
Old May 15, 2013 | 06:52 PM
Car: 89 Formula 350
Bump
Old May 16, 2013 | 10:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Looking at both BUA & ARAP, DE is disabled. So if the BIN you are using is the same you will need to set up the parameters to enable it, then tune it in.
The TPS% filter is set to 100%, then the delta TPS% & delta LV8 values are set very high. The amount if time in DE is set to 0, along with the IAC TF steps.
The fuel limiting factors are set to 128, which looks like that disables DE on the injector PW.
RBob.
Old Oct 7, 2021 | 10:57 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Bump for great information
Old Oct 9, 2021 | 03:14 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
IMO, if it were just a momentary spike, that kinda seems normal though with the sudden close of the throttle body. If it stood at 11.50 AFR all the way back down the RPM scale though during DFCO, I would be thinking leaky injectors. Either way, if he is reading this, I bet he is dying to have that car back. Told you not to sell it Eric lol...
- Rob
Old Oct 9, 2021 | 12:09 PM
Engine: Lb9
Transmission: M20
THIS information helped me get a car to pass emissions.
TPI-Formula350-
Jan 25, 2012 09:17 PM
Chevy86 IROC-Z
Jun 28, 2010 10:56 AM
90c350
Aug 23, 2007 01:56 PM
Ronny
Jun 7, 2004 10:12 AM
rsilver
Jan 16, 2004 11:37 AM
