new chip problems?
Car: 91 camaro rs
Engine: 350 tbi. Rv cam. Edelbrock headers
Transmission: stage 3 700raptor 2400 stall
Axle/Gears: 3.42 posi+disc brakes
new chip problems?
I need some help guys. I just put a 350 chip in my Camaro and now it is idling very high and the service engine soon light is flashing any ideas of the problem?
Transmission: 5-speed/T-5
Re: new chip problems?
Wrong EPROM, or inserted wrong.
The flashing CEL is indication that the EPROM is bad, not correct application, or inserted wrong, and is in limp home mode.
Car: 91 camaro rs
OK I'll try flipping it around and see what happens
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Unless its been changed to a 28 pin solder in d2 the prom will be in a Robinson nugent holder and can only go in one direction.
Car: 91 camaro rs
Alright it is in an rn holder but the chip isn't like the ecu has it but not the chip.
So now the ses light is just flat on and still high idle
Engine: Lb9
Transmission: M20
The prom notch allways goes towards the notch of the holder. If the mil is on check for codes. I have never put a prom in backwards it could be fried.
Car: 91 camaro rs
Yeah its fried I'm getting a memcal error code now
To say it is an absolute is not correct. While the EPROM is often damaged when inserted backwards, it is not always the case.
Street Lethal
Apr 30, 2019 12:14 PM
NBrehm
Aug 25, 2015 11:49 PM
