looking for EBL help
Old Aug 11, 2013 | 11:26 AM
90454ss's Avatar
Car: 90 454 ss
Engine: BBC
Transmission: T-400
I have a 90'454ss pick up with MPFI controlled by EBL. The truck runs good in open loop after many VE learns , but not back in closed loop. The NB 02 does not seem to read right, always too rich at idle - even in open loop.
The wide band seems to track fine? What am I missing? Could someone review my file and give me some direction please?
Thanx Charlie
Old Aug 11, 2013 | 12:10 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: looking for EBL help
Where is your .bin? Post/attach it...
Old Aug 11, 2013 | 01:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The NB o2 sensor may be silicone poisoned. They report rich when they are. It will actually drive the INT & BLM down to the point that the engine cuts off (BTDT).
RBob.
Old Aug 12, 2013 | 02:28 PM
90454ss's Avatar
Car: 90 454 ss
Engine: BBC
Transmission: T-400
https://www.dropbox.com/s/keshhbr94r...ning_00153.bin
here is the bin. My buddy uploaded it to dropbox for me
The o2 sensor is brand new and was just swapped out. I am sure it is not fouled.
Old Aug 14, 2013 | 11:18 AM
90454ss's Avatar
Car: 90 454 ss
Engine: BBC
Transmission: T-400
please someone review my file & tell what I'm missing.
Old Aug 14, 2013 | 05:51 PM
Is this a stock 454? Your Initial - SA is set to 9.14 degrees, way too much, stock calls for 4-degrees I believe, while your Idle State - SA is set to 11.95*, way too little, as stock calls for 16-degrees. Only other thing that I noticed is that the Injector Flow Rate is missing, it is set to 0, as well as the Displacement of 1 Cylinder, that is also set to 0...
- Rob
Old Aug 14, 2013 | 06:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
- Rob
It is an EBL Flash ECM, uses a different XDF file. There is a table of BPC values in place of the individual fuel rate and displacement parameters.
90454ss, a log file may be helpful.
RBob.
Old Aug 14, 2013 | 06:09 PM
Originally Posted by RBob
It is an EBL Flash ECM, uses a different XDF file...
I've gotten so used to the P4...
Old Aug 14, 2013 | 07:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It's understandable. The EBL systems are very similar, with subtle differences between them.
RBob.
Old Aug 15, 2013 | 11:22 AM
90454ss's Avatar
Car: 90 454 ss
Engine: BBC
Transmission: T-400
RBob.
OK I will record and post a log , should I post both open & closed loop?
Old Aug 15, 2013 | 11:28 AM
90454ss's Avatar
Car: 90 454 ss
Engine: BBC
Transmission: T-400
- Rob
no not stock but milder 30 over 454 10.5 cr , alum oval port heads, multi port with 44lbs injectors. cam is 226- 234 @50. with 112lsa .
Old Aug 23, 2013 | 04:59 PM
Doober's Avatar
Car: '92 GMC C1500 RCSB
Engine: TBI + Vortec + EBL 383
Transmission: 4L60
Axle/Gears: 3.08
I had the same problem when I first got an EBL, was running it on my stock TBI 4.3 to get used to the setup, TunerPro, etc. In closed loop it would come to the point of stalling, a new O2 sensor solved it.
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
