305 TBI TFS 175cc heads tuning help
Old May 28, 2014 | 06:01 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
quick rundown just looking for a little help tuning this thing ... 1991 LO3 with stock bottom end balanced with all arp bolts and studs , sped pro hyper flattops 5cc reliefs 10.5:1 CR, trick flow 175 heads 56cc chambers , howards HR cam 214/218 @.050 268/270 ADV. .488/.495 lift on 114 LSA 110 ICL , 1.6RR comes to .520/.528 lift , comp short travel roller lifters, summit stage2 dual plane intake ported and center divider cut down, summit shorty headers 1.5 primaries 2.5 collectors ,2.5 Y pipe ,3" full exhaust into flowmaster crossflow .....dadalogs and bin attached
File Type: zip
File Type: zip
File Type: zip
Old May 29, 2014 | 08:44 AM
whatif3387's Avatar
Re: 305 TBI TFS 175cc heads tuning help
I took a look at the 2nd log and noticed that during your WOT run you were hitting way over 85% duty cycle which isn't good. As to why I cant really give you a definitive answer I'm sure others here can help much more then I. Based on my own experience your fuel pressure may be to low you didnt mention what pressure your running. Other things that can also cause this to happen are really big dips in the upper ve tables which you do have from what I saw. Your tables could also use some more work they need to be alot smoother with no sharp transitions. This is just coming from my own experience so I'm not stating any of it as fact besides knowing that you need to take care of the duty cycle issue. If you don't get any other replys here I suggest emailing your datalog and bin to rbob. Your datalog also didnt include the WB02 data. I've run into this issue myself on the laptop you recorded the datalog with you need to convert to a .csv to read in excel before moving the .dat file. If you email or post just the .dat file like you posted before converting it the WB02 data will be missing which is definitely helpful to have when reading a log.
Old May 29, 2014 | 10:25 AM
Ronny's Avatar
your set up is similat to mine. I see EBL flash. I assume you have done multiple learns.
What drivability issues are you hoping to address?
Are you using the WB as a substitute for NB? Have you tried to tune with NB?
Old May 29, 2014 | 12:30 PM
Car: 1991 firebird
Axle/Gears: 4.10
I have wb and nb ... I'm not really having driveability issues just trying to get the most power I can out of my setup ... and get my fueling consistent ... I know my sa tables prolly need some work .. I'm fairly new to the whole tunning thing and just want it to b the best it can b ... fast 355 told me to start this thread in my build thread titled LO3 rebuild HP estimates
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades. 24mpg @ 2500rpm hwy. 8.80@ 84mph 1/8th on street tires... 8.000's soon
Old May 29, 2014 | 02:16 PM
Ronny's Avatar
Tune so the AE ceases just after the PE begins in your logs with good launch. Change the A/F ratio in PE to allow the best MPH in 1320 feet. Same for SA adjustments in PE at same 1320. I am at 37 deg at WOT 100MAP at red line. Edelbrock RPM 64cc.
Or dyno time.
Old May 29, 2014 | 02:44 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I am to lazy to open your bin but I will take a look at your SA main table and VE table if you can post a print screen of them.
Also need to know your current fuel pressure and injectors size.
Old May 29, 2014 | 03:39 PM
Car: 1991 firebird
Axle/Gears: 4.10
I'm running 68# injectors at 28 psi wot with VRFPR so it runs around 18psi at idle
Old Jun 1, 2014 | 06:45 AM
Car: 1991 firebird
Axle/Gears: 4.10
Any tuning gurus wanna help me get the last 10-15% outa this thing ?
Old Jun 1, 2014 | 08:07 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Get rid of the Ypipe and shorty headers.
Old Jun 1, 2014 | 08:23 AM
Car: 1991 firebird
Axle/Gears: 4.10
Got a baby girl gonna b here in 3 weeks ... No spare cash ... I just want somebody to look over the tune n point things out I need to work on
Old Jun 1, 2014 | 09:08 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Upload a datalog in .dat format, I will look at it in the WUD...
Old Jun 1, 2014 | 10:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For anyone wanting to look at EBL .dat data logs, the WUD programs can be downloaded from our web site. Be sure to use the correct one for the EBL system that created the log.
For the EBL Classic and EBL Flash, the WUD for looking at data logs is interchangeable. You can use either the EBL Flash or EBL Classic WUD for either system.
For the EBL P4 and EBL SFI-6 systems, need to use the WUD for that system. Note that they will each display the other systems log file, but some data may not be correct.
RBob.
Old Jun 1, 2014 | 03:02 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Did not realize that you were not using a wideband. Just looking at the VE tables and the narrowband 02 sensor, the thing seems like it is probably running very rich up top. Also notice in one of the acceleration runs, something that looked like clutch slippage as the RPM was near 6,000 rpm.
Old Jun 1, 2014 | 05:03 PM
Car: 1991 firebird
Axle/Gears: 4.10
I am running aWB here it is in the same log I posted .. Huh ? ....
Old Jun 1, 2014 | 05:06 PM
Car: 1991 firebird
Axle/Gears: 4.10
Click image for larger version
Attached Thumbnails 305 TBI TFS 175cc heads tuning help-forumrunner_20140601_180451.png
Old Jun 1, 2014 | 05:08 PM
Car: 1991 firebird
Axle/Gears: 4.10
Old Jun 1, 2014 | 05:09 PM
Car: 1991 firebird
Axle/Gears: 4.10
I'll try in morning
Old Jun 1, 2014 | 05:11 PM
Car: 1991 firebird
Axle/Gears: 4.10
RBob.
Any words of wisdom rbob ? .... I copied a lot of tables out of your 327 cu in bin it seemed to b a similar build
Old Jun 1, 2014 | 06:16 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Attachment 278309
Attachment 278310
Attachment 278311
Oh..Just figured it out. I do not have a wideband configured in the What's Up display. What type of wideband and what channel is it installed on? Want to look at your air/fuel ratio.
Old Jun 1, 2014 | 07:09 PM
Car: 1991 firebird
Axle/Gears: 4.10
I'm using rbobs tt1 WB on Channel 0
And autometer 0-30psi .5-4.5v fuel pressure on Channel 1
Old Jun 1, 2014 | 07:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Ok, got it all in place, notice several different things. Perhaps my XDF file V21 is behind the times. Is your whole 6375 RPM table on the VE table set to 0?
I noticed your AE settings allow far too much AE during the shifts. Also seems like your fuel pressure is bouncing around alot at WOT.
You are also dropping out of PE during the shift. I would set your PE TPS table values above 3,200 rpm to ZERO. This will keep the target air/fuel ratio at PE value during the shift. Then work on DE to help keep the air/fuel ratio from going so rich. Might also add some extra throttle follower at high RPM. Set your IAC MAX TF Steps from 160 to 255. This will help get you some more airflow through the throttle body at WOT. This will also help combat that rich spike when letting off the throttle by keeping the airflow greater.
Old Jun 2, 2014 | 06:20 AM
Car: 1991 firebird
Axle/Gears: 4.10
Thanks A lot fast ! I'll change the things u mentioned asap ! ... And my 6375 row is not zero ... I posted a few pics a couple posts back of sa and VE graphs
Old Jun 2, 2014 | 07:25 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Fast,
Would you suggest maxing out the IAC at WOT even for an SPFI system? My MAP can be 100+ at WOT.
Are u using more TF at higher rpm to keep revs up during shifts?
Old Jun 2, 2014 | 10:15 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Fast,
Wouldn't hurt to try IMO. It can help keep the revs from dropping off as quickly and keep the mixture from spiking so rich when the throttle is closed.
Old Jun 2, 2014 | 10:53 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Got it.
Old Jun 4, 2014 | 07:20 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
One other thing I suggest is looking at your rev limiter. Both SA reduction and Fuel Cut-off. I think I saw values of 7k. Not needed with a 6k shift point. I would pu the SA reduction to 6k and fuel kill at 6,200.fuel resume can be 5,900.
Old Jun 4, 2014 | 11:04 PM
Car: 1991 firebird
Axle/Gears: 4.10
Well I got everything suggested so far changed.. I believe IMA go to the local track tomorrow night so we will c what happens .. So I'll have a few more 1/8th mile datalogs with the current bin
Old Jun 5, 2014 | 05:18 PM
thomas1976's Avatar
Car: 91 Trans am
SA table looks good how does it feel from 1000 to 4000 rpm? for curiosity do you have a pic of the VE tables too?
Old Jun 5, 2014 | 05:55 PM
Car: 1991 firebird
Axle/Gears: 4.10
Yea I posted pics of VE AE &SA all at same time do they not show up for y'all ? Its like post 15 in this thread ... And 1000-4000 seems ok I guess but it really don't start pulling hard till 4k and up ... A little more torque on the little end would b great ... The only lace I've ever seen ANY knock counts the whole time is the low rpm low map area around 1000-1500rpm and 25-45 map or kpa or whatever ... Low load not high load lol
Old Jun 5, 2014 | 06:21 PM
thomas1976's Avatar
Car: 91 Trans am
Yes the graphic of the VE table are there but a pic of the VE table with the numbers would be great.
Old Jun 5, 2014 | 07:32 PM
Car: 1991 firebird
Axle/Gears: 4.10
Here is what I had at the time I started the thread recently made some changes about to post current ve next .. And I have done both WB and BLM learns
Attached Thumbnails 305 TBI TFS 175cc heads tuning help-forumrunner_20140605_192832.png
Old Jun 5, 2014 | 07:41 PM
Car: 1991 firebird
Axle/Gears: 4.10
Attached Thumbnails 305 TBI TFS 175cc heads tuning help-forumrunner_20140605_193358.png   305 TBI TFS 175cc heads tuning help-forumrunner_20140605_193344.png   305 TBI TFS 175cc heads tuning help-forumrunner_20140605_193301.png   305 TBI TFS 175cc heads tuning help-forumrunner_20140605_193837.png   305 TBI TFS 175cc heads tuning help-forumrunner_20140605_193901.png
Old Jun 6, 2014 | 06:25 PM
Car: 1991 firebird
Axle/Gears: 4.10
Well don't look like ima get yo the track this week .. Its been pouring down rain for 3 days on and off :-/ ... I wanna break 8.50 on street tires! Anyone think that's out of the question ?
Old Jun 9, 2014 | 10:56 PM
Car: 1991 firebird
Axle/Gears: 4.10
Bump
Old Jun 10, 2014 | 07:44 PM
worme6's Avatar
Car: 88 Formula, 85 Corvette, 90 GMC P/U
Engine: 305 TBI, 350 L98, 350 TBI
Transmission: 700R4, 4+3 man, 700R4
Axle/Gears: Stock
I have a set of the tfs heads and hooker 2055 headers to go on my 305tbi. Having to build in stages due to money. Can I put them on with stock program for 88 firebird computer or do I need to wait?
Old Jun 11, 2014 | 01:07 AM
Car: 1991 firebird
Axle/Gears: 4.10
About the most u can do with a stock tune is headers , full exhaust system ( go single 3.5" mandrel bent) intake and throttle body mods, and 1.6,roller rockers ... Them u still need to advance ur base timing from 0 to 2-6 degrees and bump fuel pressure to 15psi ... But a GOOD tune will bring out the most of any mods u make .... Soon as u change compression, heads, or can a tune is a must !!!!..and us gonna need to upgrade ur fuel pump for anything over 250hp ... Also I soul's go with a little biger can than I went with ... I'd say 220+@.050 intake ... And try to getí as close to .550 lift as possible to get these heads in their sweet spot lll
Old Jun 11, 2014 | 01:31 AM
Car: 1991 firebird
Axle/Gears: 4.10
And if the heads r gonna set for awhile u need to soak em in WD 40 n saran wrAP em
Old Jun 21, 2014 | 01:33 PM
Car: 1991 firebird
Axle/Gears: 4.10
Bump
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades......... 24mpg @ 2300rpm hwy 65mph ........ 8.63@ 85mph 1/8th on street tires... 8.000's soon
Old Jun 26, 2014 | 12:33 AM
Car: 1991 firebird
Axle/Gears: 4.10
Bump
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
