7730 SA Table Definition Check
Old Nov 4, 2014 | 11:24 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
For the 7730 with the $8D mask,,,,
Base Timing = + 10 degrees.
SA Table (@ select kPa & RPM) = +20 degrees.
Is the "total" advance +20 degrees or + 30 degrees to TDC?
Best Regards,
Bruce
Old Nov 4, 2014 | 11:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 7730 SA Table Definition Check
+20 degrees
See:
https://www.thirdgen.org/techbb2/sho...hreadid=317768
RBob.
Old Nov 4, 2014 | 08:08 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Thanks RBob,
That's what I thought. The SA Tables indicate total advance relative to TDC.
Just thought I would check.
Best Regards,
Bruce
Old Nov 6, 2014 | 04:42 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Nice paper. A good read!
Given the $8D Mask, is there any ALDL Spark Adder to the Total SA?
Best Regards,
Bruce
Old Nov 21, 2014 | 06:50 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Best Regards,
Bruce
See attachment for $8d spark calculation.
File Type: doc
Old Nov 21, 2014 | 08:05 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
84Alky,
Thank you.
Very nice paper on the $8D Spark Advance calculations!
Best Regards,
Bruce
Old Jan 4, 2015 | 11:07 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
84Alky,
Is there a way to program the ECM to always use the "Closed Throttle" SA Table instead of going to the Main SA Table (100 KpA column) for temperatures at or below 113 degrees F?
I found a parameter at 0x31. Not sure if this is related to the Closed Throttle SA set-up?
Best Regards,
Bruce
Old Jan 4, 2015 | 03:35 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
84Alky,
Best Regards,
Bruce
Absoultely! But you will need the new S_AUJP v5 release which provides it. Go here:
https://www.thirdgen.org/forums/diy-...available.html
S_AUJP v4 included this feature but it has a subtle bug which was fixed in v5. The READ ME FIRST....doc provides details on what to do to use the feature.
Azrael91966669
25
Jun 20, 2017 04:04 AM
86CamaroDan
Sep 29, 2015 10:08 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
