Tunerpro
Old Nov 12, 2014 | 04:18 PM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Tunerpro
So I'm 100% new to this tuning thing and wanting to learn I have tuner pro rt and idk how to use it yet still learning and need some help teaching iv searched everything I can think of and did not really get much out of the stuff I have read here or few other sites I can't think of them off hand but I read everything I could on Google but the goal here is being about to tune my lo3 to run good I have the lt1 came tbi spacer shorty headers msd dizy and wires tpi fuel pump I feel like I should make a chip after having this stuff for a year now it runs decent but Ik there is a lot more power so help getting started on tuner pro and what I need to tune like I said I'm new to this and never tuned before and idk how to load the stuff on tuner pro yet either I been playing with it when I can in between classes but my surface pro 2 should be here soon and thats what I plan using to tune
Old Nov 12, 2014 | 04:40 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: Tunerpro
Suggest you
1. use punctuation.
2. Be specific as to what the problem is.
3. Be specific as to what you have tried to solve it.
4. Be specific on what your question is.
TP works there are some hurdles that may be with the PC hardware, PC software, cable, or in TP.
Old Nov 12, 2014 | 05:37 PM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Re: Tunerpro
Ok well I wanna know the best place to start. For a new tuner that knows nothing. I know nothing about bins or the Xdf, or the other things that are needed I can't remember i don't have my computer right now to check.
Old Nov 12, 2014 | 06:07 PM
TallTim's Avatar
Re: Tunerpro
OK so learn the basic terms and concepts. It's all online or in TP, no sense repeating here. Then connect to the car and see if you can read in real time. That will be big progress.
Old Nov 12, 2014 | 06:22 PM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Re: Tunerpro
Ok so what is the best table to start with the SA, or fueling or something else sorry I just want to hear what you guys with experience have to say and I saved the 2 files off of tuner pro but I don't really understand what there for
Old Nov 15, 2014 | 09:17 AM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Re: Tunerpro
ok so the lo3&lo5 Datastream Definition off of tuner pro for the 82-92 F&B body is that the stock file I need I was looking through it after I took it from ads to adx and it looks like it was changed I think that's the file that has all the data installed but everything I have is off of tuners pro website I have my bin from there and there was two bin files in tuner pro when I downloaded it and I got my adx file from there site in the Datastream Definition table for my car then abd under Bin definition is were I got my xdf file so I just need to know if im doing this right or not
Old Nov 15, 2014 | 09:26 AM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Re: Tunerpro
ok I just saw a hyperlink on there page that took me to more Datastream Definition and I found A083 is this what I am needing sorry just want to be sure
Old Nov 15, 2014 | 02:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tunerpro
What I get is: '89 305 with the L03. If correct, that uses the '8746 ECM which is MaskID $61, that is the secret decoder key.
You need the $61 ECU or XDF file to edit the BIN
Need the $61 ADS or ADX to monitor/log the ALDL data stream
Of course need Tuner Pro RT to be able to connector to the ALDL stream and edit the BIN.
As for hardware, need an ALDL to USB cable.
Now you can set up and get the data logging working.
To do 'chips,' need the G2 adapter, some 29sf512 chips (27sf512?), and the Burn 2. The adapter gets soldered into the ECM, then the 'sf512 chips can be used.
See www.moates.net
RBob.
Old Nov 15, 2014 | 08:52 PM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Re: Tunerpro
Ok the other bins I got were here http://www.gearhead-efi.com/Fuel-Inj...Information-61 and do I need the adapter I thought all I needed was a prom burner but I was wondering about the emulators would that make tuning easier or make things more complicated I'm just trying to get a good tune for my lo3 lt1 cam headers tbi spacer and the tbi mods and for the data cable I got an rftdi chip and gonna use that tell I l go back to work in Jan since I dont make any money while I'm at school I can't drop 80$ for a cable
Old Nov 30, 2014 | 11:36 PM
LlamaJWC's Avatar
Re: Tunerpro
These are all questions that can be answered by reading up on the stuff, research. Whether your on Moates, Tunerpro website. Or when you download and open up Tunerpro RT and click Help -. Help Topics. or hitting the F12. it tells you all the basics from the meaning of the ADX, TDX definition files, to familiarization, to beginner operation.
Than the moates website will show if and what adapter you need to hook up to the ECM board, or the ALDL cable. once you get connectivity with the vehicle, than you can load the ADX,TDX files in question. In 2 seconds that'll tell you if they're the correct defintions. Theirs a lot to know. Even more information available at our finger tips. just going to take a lot of reading and familiarization
Old Dec 15, 2014 | 11:28 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: Tunerpro
TO tchampton.
what school did you go to that they never taught punctuation and capitalization please use punctuation and capitalization you don't realize how hard it is to understand what you are is saying because we can't tell where a thought starts or ends because its just one great big run on sentence that just keeps going on and on and never really gets to a point AND WE DECIDE NOT TO READ THIS JIBBERISH SO YOU DON'T GET ANY USABLE ANSWERS
You'll find a great deal of prep work available in the stickies at the top of the heading. Although some is outdated, and have lost links, it's a good place to begin to learn. I still go back to it a few times a year to get e refresher course on things.
Dave
Old Dec 31, 2014 | 03:13 PM
ChevyTycoon's Avatar
Re: Tunerpro
Did you go through this section yet?
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Jan 2, 2015 | 01:27 PM
Ronny's Avatar
Re: Tunerpro
tchamp: Check out he stickies above. Also in TBI is a sticky called "free tune". very helpful.
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
