Pocket DataLog for Android
Old Mar 5, 2017 | 01:53 PM
jdarg's Avatar
Car: OT TBI Jeep
Engine: 5.7L
Transmission: AX15
Axle/Gears: 4.88
I'm going to start my own thread for Pocket DataLog.
Here's a teaser of the WUD capabilities I'm working on currently. Its still a little rough and some things are still not working in the UI but it won't be long.
Old Mar 5, 2017 | 02:05 PM
gibbles's Avatar
Car: 84 Corvette Z51 ("The GoCart")
Engine: 350(CFI)
Transmission: Built 700R4 w/3400RPM 9.5in stall
Axle/Gears: 3.07 (D36)
Re: Pocket DataLog for Android
Posting to subscribe, and to hopefully send my error logs/troubleshoot!
Old Mar 5, 2017 | 02:17 PM
jdarg's Avatar
Car: OT TBI Jeep
Engine: 5.7L
Transmission: AX15
Axle/Gears: 4.88
It looks like it posted the error to my Android developer console:
java.lang.NullPointerException
at com.felhr.usbserial.UsbSerialDevice.createUsbSerialDevice(UsbSerialDevice.java:68)
at com.felhr.usbserial.UsbSerialDevice.createUsbSerialDevice(UsbSerialDevice.java:58)
at com.brewcitycrawlers.pocketdatalog.UsbService$ConnectionThread.run(UsbService.java:274)
Seems the third-party serial library I'm using doesn't like your USB serial adapter for some reason so let me know what kind it is. I'll dig into the serial library probably next weekend and see if its something obvious/simple for me to fix.
Old Mar 5, 2017 | 02:27 PM
gibbles's Avatar
Engine: 350(CFI)
I think i got my adapters mixed up, the one i swore came with the ebl says xchip-x.
The other one i thought i bought for my wide band O2, says trendnet TU-S9.
​​​​​​​I just swapped them and the trendnet adapter is working!
Old Mar 5, 2017 | 02:59 PM
gibbles's Avatar
Engine: 350(CFI)
The xchip-x adapter; i confirmed it came with my ebl last year.
I found the trendnet adapter in my amazon order history, i ordered it with my wideband O2 last year.
Not sure if the xchip-x adapter is being sent with current ebl orders, or if i just got "lucky", rbob may be able to confirm.
Old Mar 6, 2017 | 02:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The current USB to Serial adapter cable that goes with the EBL is the FTDI Chipi-X cable. It may have crashed the app if the drivers weren't installed. Can get it here:
http://www.ftdichip.com/Drivers/D2XX.htm
The trendnet cable uses the Prolific chipset and uses a different driver.
RBob.
Old Mar 9, 2017 | 04:06 PM
jdarg's Avatar
Car: OT TBI Jeep
Engine: 5.7L
Transmission: AX15
Axle/Gears: 4.88
Thanks Rbob.
I'm using a free third party serial library that started out pretty well maintained last year but its been languishing a bit since fall. It does indeed look like it is built on an older d2xx jar file.
I should be able to get everything to play nicely with the latest one. Give me a few weeks gibbles. I'll try to get it in the next release.
Old Mar 9, 2017 | 05:41 PM
gibbles's Avatar
Engine: 350(CFI)
Thanks!
I sent more logs via the app again invase it's helpful, and more info...
The working adapter crashed the app today when i connected ebl to my phone...
So i connected my micro usb adapter to my phone, launched the app, and then connected the serial adapter/ebl.
It worked!
So i did the same with the xchipx adapter, and it worked as well!
I can repro the crash on demand at this point if you need anything else, i can also enable developer mode on my device if you need something fancy.
Old Mar 9, 2017 | 07:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Wish I was younger and could pick this stuff up easy, I could use something like this
Old Mar 10, 2017 | 09:47 AM
jdarg's Avatar
Car: OT TBI Jeep
Engine: 5.7L
Transmission: AX15
Axle/Gears: 4.88
Thanks gibbles. Check your PM - I just need to clarify the steps I would use to reproduce the crash. That's good news I don't have to dig into the code for the serial library though...I wasn't looking forward to that because it would steal time away from the important stuff.
Old Mar 11, 2017 | 10:32 PM
gibbles's Avatar
Engine: 350(CFI)
I sent a good solid repro, works flawless each time if i connect all of the adapters in stages.
I have been using the app as a solid lockdown for my car.
took some logs with it today, working great!
​​​​​​​The playing lego is anoying, but it's nice to be able to use my phone since it's almost always with me.
Old Mar 16, 2017 | 02:02 PM
jdarg's Avatar
Car: OT TBI Jeep
Engine: 5.7L
Transmission: AX15
Axle/Gears: 4.88
Try this and let me know if it also seems stable w/ no errors. Android recently changed up their permissions handling, and I had to modify the app to work with that on the second release. I can't seem to recreate any of this crashing on a newer OS with the new permissions model and I no longer have any 4.4 or lower devices to test with.
Plug everything together but don't make the final connection to the phone.
Bring up your background apps list, and if pdlog is already running, close it out.
Fire up the app again.
Plug in the last of the legos (the "big" to "little" usb converter) into the phone.
Let me know how this works, both with ignition on and ignition off when you go to insert the converter into the phone with a "fresh" app launch, making sure it wasn't paused in he background.
Old Mar 16, 2017 | 05:22 PM
gibbles's Avatar
Engine: 350(CFI)
I think that's whats happening, if i close the app, and i later go to connect the usb, it pops up a window and asks to connect.
It does not show up in my task manager, but if i go to settings, apps, and running, it's there.
That also explains some of the randomized working and not working i was seeing...
​​​​​​​I'll test the idea shortly, however it may not happen until saturday...
Old Mar 18, 2017 | 02:14 PM
???'s Avatar
I have an old note 2 laying around, I believe it's on 4.3 something, if it would help and you'd want it
Old Mar 18, 2017 | 06:10 PM
gibbles's Avatar
Engine: 350(CFI)
So if i ensure the data logger service has fully exited i don't have to lego it together one piece at a time.
​​​​​​​but i do need to connect the usb adapter first, then connect the serial to ebl and it's all good
And I'm. 4.4.2 (I'm sure the logs showed that).
LG left me hanging with the last updates, wifes S5 got it no problem.
However her phone can't use app ops, serious disappoint as apps can do just about anything they want...
Old Mar 19, 2017 | 04:55 AM
Bob@TriumphTr's Avatar
Hi
I am running it on my Samsung Galaxy S2 tablet. Android 6. Works fine. According to the play store it's not compatible. I had to side load it . The play store refers to version 1.03 but the version I running is v 1.10.
As I am in Europe I more used to the metric system. Maybe a nice option for the future.
Regards
Bob
Old Mar 25, 2017 | 12:47 PM
Hi
Connecting the serial to USB adaptor through the mini USB port is a week point. Apparently there are serial to Bluetooth adaptors. Would it be possible to connect to pocket data through Bluetooth? Wouldn't that be terrific. Just get in the car and it pairs
Old Mar 25, 2017 | 06:10 PM
gibbles's Avatar
Engine: 350(CFI)
I would love a Bluetooth adapter, would make it easier as i also use this to lock the car via bank switch.
Old Jun 13, 2017 | 02:48 PM
RF_Burns's Avatar
Hi Jdarg,
I looked for your Pocket Datalog on Google Play but I can't find it through my phone. I can find it on my desktop though.
I'm in Canada, is it locked out from being accessed here?
Old Jun 13, 2017 | 02:58 PM
Hi Here is a link.
I had to sideload mine
https://play.google.com/store/apps/d...tdatalog&hl=nl
Old Jun 13, 2017 | 10:43 PM
old man winter's Avatar
I'd like to second that request for availability in Canada. This looks very exciting, would love to leave my crappy windows tablet home and just take my phone instead. Would also like to second that request for bluetooth to serial connectivity we use these adapters in the agricultural world to transmit internet based correction signals from a cell phone to gps receivers for auto guidance on tractors, works very slick.
Old Jun 16, 2017 | 05:59 AM
https://m.apkpure.com/pocket-datalog/com.brewcitycrawlers.pocketdatalog
found it in Canada, looks great can't wait to try it out thanks for the effort
Old Jun 16, 2017 | 12:14 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Iphone user here but subscribing cause this is definitely interesting.
Old Jun 21, 2017 | 07:12 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
This is awesome
Old Jul 14, 2017 | 04:32 AM
Man I used the datalogger tonight and it works like a champ!
Old Jul 15, 2017 | 05:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thread is back on track.
robertfrank, you may be able to see your sig pictures, but photobucket is blocking others from seeing them.
RBob.
Old Jul 15, 2017 | 06:46 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Thank You RBob. All i'm seeing is circles, no pics
Old Jul 15, 2017 | 07:36 PM
gibbles's Avatar
Engine: 350(CFI)
Thanks rbob
Old Dec 31, 2017 | 12:59 AM
Almost3rdgen's Avatar
Great thread and great work. I'm posting to subscribe.
Old Aug 22, 2021 | 04:57 PM
billvv's Avatar
I was unable to find the Pocket Datalog app in Google Play; it it still available and/or supported?
Old Aug 29, 2021 | 09:42 AM
jdarg's Avatar
Car: OT TBI Jeep
Engine: 5.7L
Transmission: AX15
Axle/Gears: 4.88
I've actually been working in this again since I've wrapped up a couple other OT projects. I never removed it from the store but Google started blocking apps built on older api versions sometime back and this is probably the issue. I need to update the api and add some additional security features before I can make it active in the store again. I don't have an ETA but hopefully in the next month or so.
Old Mar 1, 2022 | 06:34 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Forgot about this thread, then it popped up. Any more progress on updating the API? I don't know how to do it, but this was always cool!
Old Mar 2, 2022 | 06:45 AM
jdarg's Avatar
Car: OT TBI Jeep
Engine: 5.7L
Transmission: AX15
Axle/Gears: 4.88
Hello, yes, I do have an updated version that I'll be getting back into the store once I get to a better place on another project I'm working on. Hopefully late March or April.
Old Mar 2, 2022 | 07:56 AM
I've been using it with my ebl flash and its awesome. Looking forward to the new updates
Old Apr 26, 2022 | 09:39 AM
liquidh8's Avatar
Transmission: 2004R
Still watching this.
Old Apr 26, 2022 | 11:59 AM
TTOP350's Avatar
I'm hoping to have a little time tonight to look into this
Old Oct 25, 2023 | 03:53 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I did not know this was available. Sure beats finding a spot to place my laptop in the car besides the floor.
Fred
Old Oct 25, 2023 | 04:02 PM
billvv's Avatar
Fred
Let me know if you find it on Google Play; I can't.
Old Oct 25, 2023 | 08:00 PM
Fred SS's Avatar
Transmission: 2004r
I could not find it either. The OP posted he is working on an update.
Fred
Old Oct 25, 2023 | 08:43 PM
billvv's Avatar
A year and a half ago.... it sounds like a project that's on the back shelf.
Mastiff
87
Aug 10, 2017 08:08 AM
gbettner
Dec 12, 2014 07:04 AM
malcom2073
May 7, 2008 12:44 AM
onebinky
Nov 15, 2004 09:14 PM
clippjr8
Feb 11, 2004 09:26 PM
